Asus Graphics Card
The power supply in my computeris 300 watt s.
Is this sufficient to power an Asus EAH2400PRO/HTP graphics Card
  • Trick1 Dec 14, 2007
    Thank you for your very valuable assistance. as suggested I used the Extreme calculator to figure my power consumption and I am within the allowable limits, so I can use the HD2400 Graphics Card.
    Problem Solver:
  • 17 Answers
The 2400Pro graphic card uses very light power, so if your powersupply gives a true 250W or more you should be fine. However it also depends on what is your total configuration, as in whats your CPU, how many hard disks, etc as these all consume power.
A good way to check how much your machine actually needs is to use the PSU (Power supply unit) calculator. A good one i came across is
You can find your how to calculate your current PSU wattage from this interesting discussion
Posted on Dec 11, 2007
I see it is the VM/S version, and not the Asus O.E.M. version above.
My thinking is the motherboard was made for a proprietary computer manufacturer.
Perhaps NEC or Packard Bell.
Using this line of reasoning, it is my contention that the graphics expansion slot is the same, and motherboard chipset; for the VM/S version, as well as the Asus OEM VM version.
Going further...............
Graphics Expansion slot -
AGP and 8X........AGP 8X
Motherboard Chipset:
SiS 661FX - Northbridge chip
SiS 964 - Southbridge chip
So we know the motherboard will support an AGP 8X graphics card.
Another item you need to have knowledge of, is what is the Minimum power requirement; for the particular AGP 8X graphics card you are looking at......
Let's look at some examples,
(They are getting fewer, and fewer; as the graphics card technology has gone to PCI Express.
PCI Express has evolved to the PCI Express 3.0 technology now)
Scroll down to - Features
-> Minimum PSU Wattage requirement
(Ignore of you are aware;
PSU = Power Supply Unit
The Power Supply's used in personal computers are SMPS.
Switched-Mode Power Supply)
MINIMUM power wattage requirement for the above AGP 8X graphics card, is 250 Watts.
Something I would like to impart;
Back in the day Power Supply manufacturers 'fudged' the True, Actual maximum wattage rating.
Actual maximum wattage rating, was more like 60 to 70 percent of what was stated.
If we use a 250 Watt PSU from back in the day, as an example; actual maximum rated wattage would be 150 Watts, to 175 Watts.
[Simple equation(?);
250 divided by 10 = 25
25 times 6 = 150
25 times 7 = 175 ]
DO NOT under power a graphics card!
A) It will not work right, or at all.
B) It will burn;
The gold plated contact pins on the bottom of the graphics card.
The contact pins in the graphics expansion slot.
Takes a while usually, but when done you can use the motherboard for a Frisbee.
Here is a Power Supply Wattage Calculator,
Takes about 2 seconds for the page to fully load.
Need guidance in using it post back in a Comment.
It is the 'Rule of Thumb', to have at least 10 percent more power, than what is required.
Easier on the Power Supply, as it doesn't have to strain to keep up.
I myself would recommend a 350 Watt power supply, at least.
One more thing if I may;
Load all the software that comes with the graphics card.
It will be on the Installation disk that comes with it.
You will be loading the Drivers, and user interface.
For a graphics card utilizing the ATI (AMD) technology, you will be loading Drivers, and the Catalyst Control Center.
For a graphics card utilizing the Nvidia technology, you will be loading Drivers, and the Nvidia Control Panel.
AFTER doing so, THEN turn the computer off, FOLLOW Anti-Static Procedures, and Physically install the graphics card.
Because when a device is installed on a computer that has Windows on it, Windows will 'break it's neck', to find suitable, matching drivers.
If THE drivers are not already there, Windows will match up one of it's THOUSANDS of generic, one-size-fits-all drivers.
This = No
A Driver conflict can result........
Windows: "Which drivers do I use?
These or THESE?"
For additional questions please post in a Comment.
Or Reply, at the end of this solution.
1) SMPS;
2) AGP technology;
3) PCI Express technology;
May 10, 2013 | ASUS P5S800-VM Motherboard
Replace integrated Radeon 4200
You can't replace integrated graphics, the chip is on the motherboard.
See what you have for PCI-E slots, a forty dollar graphics card is three times better then your 4200.
Apr 14, 2013 | HP Pavilion Computers & Internet
No picture with GeForce 210 graphics card
Picture? Are you saying it does not work? Is this a new install? Is it setup/installed correctly? Have you installed the software? Drivers? Need more info.
Mar 20, 2013 | HP Pavilion a1423w PC Desktop
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
Does This Graphics Card Work With My Dell Inspiron 530s Even Though My Power Supply Is Only 250 Watts? Will my computer work with this card even though the PSU is only 250 watts?...
I think you're asking for trouble. The specs at the link you gave recommend at least a 300-watt supply. By the time you figure in the normal load of everything else in the system, there probably won't be enough power from the 250-watt supply to let the card work reliably, and may affect overall system operation. One of the problems with small form-factor computers is that they often use a proprietary power supply to fit the case, and you can't replace it with anything larger. This limits expansion capability. I'd suggest saving your money.
Aug 15, 2011 | Dell Inspiron 530s Desktop Computer
I was wondering whats the min power supply unit I can use with my Gigabyte GA-8IPE1000-G Motherboard? Is a 300 watt Sufficient or will it cause problems compares to the 550 watt PSU that its currently...
By lowering the WATTS from 550 down to 300, you may find the P.C. starts shutting down or restarting, as it does not have enough power to operate everything inside the tower. You need to add up all the WATTS on the different things running on power ( i.e. Motherboard, Graphics Card, RAM, Fans, Sound Card,USB plug-ins, HDD, CD/DVD drive). You maybe not have all listed but by lowering the power might be not worth it to be honest.
Aug 28, 2010 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
A display problem of monitor comes with geforce 9400 gt pci ex. card. how can i solv it? when i insert cart the display of monitor out. how can i solv it?
According to the specs of the MSI 9400gt 512mb HDMI graphics cards, its system requirements are:
1. PCI Express or PCI Express 2.0 - compliant motherboard with one x16 graphics slot.
2. Power supply of 300 (and up) watt is highly recommended for system stability.
Make sure that your power supply meets the or exceeds the system requirements for this graphics card.
My graphics card keeps resetting
go to Start/control panel/systems open systems folder go to device drivers
near the top of list will be display adapter click the little + by it a drop down list will appear right click the graphics listed go to properties/drivers click update driver it will then go on internet to find driver
that is where your cards and hardware are listed
Jul 28, 2008 | Computers & Internet
Graphics cards
should be. make sure that the power supply has power connectors for the graphics card if it needs one.
Dec 06, 2007 | S3 Chipset 8MPCI Video Card ($14/each...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
