Question about Dell Inspiron 8500 Notebook
Startup screen freezes
At first i couldn't get past the dell starup screen, but using boot menu i overcomed this problem. Now it starts up and takes me onto another screen asking if i want to start windows normally, with command prompt, etc. I choose last known configuration. It thank takes me to the windows XP loading screen and just freezes. I have left it for hours and when i came back the loading bar had not even appeared, let alone move across the screen. Any solutions would be helpful. Thanks alot Adam Czajka. Please feel free to email me at chykx@hotmail.com
  • Chykx Dec 07, 2007
    i dont have the system restore disc because i've had this pc for about 6 years, is there anyway or restoring system files by pressing a button at the dell load up screen (as soon as u turn on the pc) any solutions would be a great help, chykx@hotmail.com
  • Chykx Dec 08, 2007
    I dont have any discs
Try reinstall your windows xp disc to overwrite the corrupt file,
Posted on Dec 07, 2007
  • Anonymous Dec 09, 2007
    unfortunately thats the only way to fix the problem using system restor dics or Buy a new OS to install a fresh one
  • Anonymous Dec 12, 2007
    One of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
    To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
    • Boot.ini
    • NTLDR
    • Ntdetect.com
    After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
    Scholar:
  • 112 Answers
Using the system restore disk, boot the laptop and choose repair, run chkdisk /r this repairs the system files, if this does not fix the problem, using the same system disk do a restore.
BPCS
Posted on Dec 06, 2007
Changed msconfig now will not boot
Try to start laptop in Safe Mode. Restart laptop and before black screen disappears click F8 key, wait for a while and a menu will appear having multiple options. Select Safe Mode option for windows StartUp.
Download system optimizer Reginout, Install it and by using its StartUp and Service optimizer feature adjust the startup programs.
Jan 15, 2013 | Dell LATITUDE Computers & Internet
ThMy Dell inspiron b120 couldn't shut down?
Stuck process. Use Ctrl-Alt-Del to see what is not responding, kill the process.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 24, 2012 | Dell Inspiron B120 Notebook
Its just stuck on the Dell screen at the begining energy starpage
if the system doesn't boot past the Dell Screen, the most likely issue is the hard drive.
See if you can bring up the F12 menu at boot and run HDD diags.
If you can't do that and have the dell resource cd, you can try booting to that CD, and run diags there
Apr 09, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Will not open,then can't turn off
Try starting the PC in "safe mode (with network support) " by tapping the F8 key whilst it boots up and selecting safe mode from the menu. (Which bypasses your start-up items) If this boots up ok then the problem is a program that is starting up with windows, Check the start menu / programs / startup for any programs and remove them.
You can then downlaod a free program called "Spybot search and destroy" - run it, select "mode / advanced" - Tools - Startup and remove the offending item!
Apr 28, 2009 | Computers & Internet
Dell Dimension freezes at startup
Try disconnecting the data cable from the hard drive, then see if you can boot to the Resource CD. If you can, there is a good possibility the Hard Drive is bad.
If no difference, then try disconnecting everything but video, see if the system will boot past the Splash screen. SOmetimes periferal items cause issues
Mar 29, 2009 | Computers & Internet
Dell inspiron wont start!
try to boot in safe mode thru boot menu pressing F2 or F8 or F10 when prompted on startup it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
if it doesnt help then try changing RAM
Feb 22, 2009 | Dell Computers & Internet
Open Questions:
Dell Inspiron 8500 Notebook Logo
184 people viewed this question
Alun Cox
