Question about Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 can not acquire satellites
I have a Garmin c330 gps. When I turn it on i tries to find a satellite and after a few seconds asks me if I'm indoors. I press "no" and than it asks me if I'm currently in South Carolina (that's where I bought it from) when I press "no" again it continues to search for a satellite but never finds it...
I'm currently outside of the USA but I've put in the maps of the country which I'm in. The software version is 5.7 (the newest)
I guess it got damaged (or something) when I left the USA. I had it in my suitcase which probably wasn't handled with great care ;)
Please tell me what to do with the damn thing! I need it to work.
I saw that some people have the same problem with the same unit, but no one posted any reasonable solution to the problem!
Please, HELP!
Thanks in advance!
  • 4 more comments
  • Anonymous Dec 18, 2007
    garmin street pilot c330 can not acquire satellites problems
  • Hasegawa Dec 23, 2007
    First time I used it to go to San Franciscp, it worked fine,
    on the next three trys, it could not connect with the Satelite.
    I tried today (12/22/07) and it still will not work
  • Anonymous Jan 03, 2008
    Having the same problem. Worked great the first two times we used it. Then it took about 45 minutes the next time to "acquire satellite" and the keep getting message of poor satellite reception which took anywhere from 1 to 10 minutes for it to restore. This happened the first time on a very cloudy day (snowy) so we figured that was the problem. Then it happened the next two times we used it - with the last time being a completely clear day. Obviousely weather not being the problem. Will try the suggestion to reset and see it that works, otherwise - its going back cuz its not much use when you lose directions, especially in a busy city or nearing highway exits!!!
  • Sue DeNym Feb 03, 2008
    We received this unit as a gift. I worked wonderfully the first three times. Now it can never acquire satellites. What's the problem?
  • ray miller Jun 29, 2008
    First time I used it it worked fine,
    on the next three trys, it could not connect with the Satellite.
    I tried today (06/29/08) and it still will not work
  • gman2027 Mar 28, 2009
    I have the same issue, I cannot get sattelite reception at all for a straight 10 minutes. And on top of that the dammed thing doesn't hold any charge. Even if I leave it usb- connected in my computer.
    Please Help
    Problem Solver:
  • 4 Answers
You can try both a normal reset or a master reset and see if either one works for you.
The normal reset button is behind the front bezel. You access it by using your thumbnail under the top part of the bezel and carefully pull the bezel off. Once off you press the reset button on the right side of the front face labeled reset.
Option #2 - Master reset, will lose all data.
With the unit off, use a pencil eraser to depress the bottom right corner of the screen while turning the unit on. Once on, let go of the on button and keep the lower right screen depressed and answer yes to do you want to reset unit and lose all data. Once reset you must allow the unit 45 minutes of good reception to reload all satellite data, moon data, time, etc...
Give it a try, it may work for you.
Posted on Dec 21, 2007
I've read elsewhere that the Garmin c330s will have trouble acquiring satellites as the batteries wear out, which usually happens around 15 mo. Batteries are soldered in, so replacement requires sending it in to Garmin. I've seen some reports from users who had this problem right out of the box or shortly after purchase.
Posted on Aug 24, 2008
Usually its u are somewhere where there is poor satellite signal , try to change ur place walk/ drive lill bit
I think i also faced the same problem what u can do with it is
first try to restart the unit
if still not resolved settings go to "restore settings ", switch it off again give some time then restart it again
if still not workinh go to reset button
if still not resolved "master reset" right lower corner, press for 30 seconds ( my guess) then restart
if still not resolved : call tech support : they will fix that or send a replacement LOLz anyways i received the replacement for som lill fault in display .
Posted on Apr 10, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: loose wire on my antenna, streetpilot c330
how did you replace the battery?
Posted on Jan 16, 2008
SOURCE: my streetpilot c330
Just want to updte from version 2.6 to 3 without a charge.
Posted on May 07, 2009
SOURCE: StreetPilot C330
Please tell me ,if anyone can,why my c330 goes from miltary time to reg time. I am bad at telling the milatary time..
Posted on Dec 26, 2007
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmnin C330 slow to acquire satelites.
Make sure you are not moving. This way it can triangulate better. Wait for it to recognize at least 3 satellites. Then cruise as you wish as soon as it is synced with the satellites.
Also, be sure that you are on an open field with minimal aerial hindrances.
Your problem is normal to all GPS devices. It does take time to acquire satellite signal.
hope this helps!
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Failure to acquire satellite
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
C330 Won't acquire satellites..
When Mine did that I bought an external antennea and now it works great
Jan 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
4,300 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
