Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PD25 power problem
While watching the TV l it shut-off and now has the flashing red light in the front – control panel area of the TV. I unplugged the TV all night, and this morning get the same flashing red indicator light. The light flashes a sequence of 12 times, pauses and then repeats the 12-flash again, an again. The only way to stop the flashing is by unplugging the TV. TV is out of warranty - and repair person said 12 flashes indicates need to replace PA, D, and A boards (over $1,000 to fix). Any suggestions? TV is less than 3 years old - and cost over 2500 when purchased.
  • 3 more comments
  • oseanblue Jan 03, 2008
    I have the exact same problem, 12 flashes and all. And it is just 2 years old.
  • Msk8blake Oct 05, 2008
    same problem.. TV went dead and now just a red light blinking on the front pannel , cycling every 12 blinks.
  • gholsonhome Oct 26, 2008
    I have the same problem.  We were watching the TV (Panasonic TH-42PD25) last night with no issues.  Turned it on this morning, with no power to the TV but the red light is flashing.
  • Anonymous Nov 17, 2008
    My TV is only 4 months old i unplugged it and plugged it back in and it work just fine
  • Anonymous Jan 03, 2009
    Just happened tonight.  I bought a 4 year extended warranty when I purchased the TV and it expired 2 months ago.  I guess i should be happy that I got 4 years and 2 months out it before it broke down!!
  • Panasonic Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Blank screen panasonic plasma tv
The solid red light and the glow of the screen indicated the set is on . also if set is on a red light should be emmiting from the optical out jack. Seem like you have lost audio and video. If no menu appears when pressed on remote the replace the main board. Panasonic calls this the A board.
Jan 06, 2014 | Televison & Video
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
New 42inch plasma turned off while watching, can't turn on
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
May 31, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
I have a TH-42PD25 TV. It turned off by itself. The red light on the front control panel is blinking. The TV is not responding to the power button on the remote or the front of the TV.
Here is a link to your users manual
If youre using a PC or HDMI, the manual suggests this :
Rarely, the TV will not display video in
HDMI input from devices with HDMI or DVI
output due to bad communication between the
TV and the devices. Should this happens, unplug
the HDMI/DVI device and plug it back on.
May 16, 2008 | Panasonic Televison & Video
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
2,308 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
