Question about Compaq Presario SR1000T (568657) PC Desktop
Troubleshooting no display, no booting
  • Anonymous Dec 24, 2007
    Same problem - No Bips - Cpu Fan spining ... but No Display on Monitor .
    Inserted a PCI Card - No Go .... Tried Another working Monitor - No GO ..... Removed DIMM's - No GO .... what can i do Now ??
  • Anonymous Feb 19, 2008
    When we came in this morning, the PC was making a loud vacuum cleaner sound. We turned it off & on again, but it won't boot up.
When i turn on my computer i get a sound like beep beep beep no boot
no display anything the only thing that i get is this sound....
Posted on Mar 12, 2008
  • 108 Answers
Are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
Posted on Dec 06, 2007
Fujitsu troubleshooting
Check the GPU with san external screen.
Aug 13, 2014 | Fujitsu LifeBook T730
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Dell p15s
Is it failing to show anything on the screen? Failing to boot?
Some basic troubleshooting steps:
1. If nothing comes up on the screen, first try removing your battery for a few minutes without the charger plugged in. Attempt to turn it on (it won't, but it'll discharge the capacitors). Then replace the battery and charger and try to boot.
2. Use the windows install disc to repair the operating system, simply insert it, boot from it (use F8 to select it if you need to) and hit repair when the window comes up.
3. Also, sometimes connecting to an external display (use the VGA port) can help troubleshoot whether it is a display, or a boot issue.
Jun 14, 2013 | Computers & Internet
Wont boot
Hi..
There are many problems why the computer does not boot and you have to do troubleshooting on your computer set.
you do the test is
1 - ram
2 - power supply
3 - hard disk
4 - display cards
5 - motherboard
6 - Operating systems
after you have completed the troubleshooting of one by one, your problem must be answered
TQ
Apr 29, 2011 | KDS Computers & Internet
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
Hi,my motherboard in not booting after connecting new power supply,power supply is OK,motherboard lights are on.But when start button is pressed its not showing anything
Try this site //www.dealextreme.com/.Repair tools cheap !! You need PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Price: $2.57 free-shipping_small.gif PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card costs $2.57 and free shipping.Great company.need help majortom350@yahoo.com PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Aug 22, 2009 | Computers & Internet
The display does not work anymore.
Hi, Printer Has Blank Display Issue Description: Some customers may report that the control panel display is not working on their LJ2400 Series printer. Most of the units are right out of the box. This goal of this document is to help you troubleshoot the problem and provide a solution for the customer. Symptoms Customers will see: Printer powers on, motor rotation and fan sounds can be heard during boot cycle, but the control panel display is blank and there is no backlight . Printer prints engine test page. Printer powers on, motor rotation and fan sounds can be heard during boot cycle, but there is backlight . Printer prints engine test page. Troubleshooting requested by engineers: BACKLIGHT PRESENT, BUT NO TEXT DISPLAYS Disconnect all connections to printer except for power cord. Plug power cord directly into wall outlet and power cycle. Can motor rotation sounds be heard? Reseat memory DIMM in slot. Check cable connections on formatter ? particularly control panel power (J4), ECU-Formatter flat ribbon cable (J5), and power from the ECU (J6). NO BACKLIGHT Verify that the engine is powering up when power cycled by listening for motor rotation sounds. Ask the customer to print an engine test page. (See photo below for access to engine test page button.) If engine does NOT print test page, problem is with the engine, not formatter or control panel. (Service required.) Check cable connections on formatter ? particularly control panel power (J4), ECU-Formatter flat ribbon cable (J5), and power from the ECU (J6). Verify boot select jumper on the formatter PCB is installed on the bottom two (correct) pins (see photo below) to ensure the unit ?boots? from the firmware chip on-board the formatter. NOTE: The BOOT SELECT position (top two pins) is only used to boot from a FW-loaded compact flash card. If incorrect, reseat boot select jumper onto the bottom two (correct) pins. Attempt to print a configuration page ? ?back? button (x3, to clear any undisplayed messages) -- check button -- down arrow -- check button -- down arrow -- check button. If configuration page prints, verify contents and, assuming you find nothing wrong with configuration, you may assume that the problem lies with the display portion of the control panel. Rgds, Nikhil
Jun 30, 2009 | HP LaserJet 2420 Printer
Alienware Desktop will not boot
Try removing the RAM as well and see if it beeps...
Feb 11, 2009 | Intel D945GNT Motherboard
Compaq Presario SR1000T (568657) PC Desktop Logo
232 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
