Protron PD-DVR100 DVD Recorder
Problem for Protron PD-DVR100 DVD Recorder
I can't get it connected to a LCD TV which is
By degoodd on Aug 31, 2009
I can't get it connected to a LCD TV which is hooked up to Dish Network via HDMI. I can get it to play, but not record. I can't find the source channel even if I scan the channels. I check out the wiring scheme at Dish Network for HDMI and tried it, but still no way to get to the recording feature
Comments:
Aug 31, 2009
- I tried hooking up the receiver directly to the DVR100 and it didn't change anything. I still cannot use the recorder
Sep 01, 2009
- The last solution worked great. Thank you for your help.
Best Solution
posted on Aug 31, 2009
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3802 votes
Hi and welcome to FixYa,
Your main query of "...no way to get to the recording feature..." would largely be dependent on what device (brand and model number) is being used to receive Dish Network channels and in part to the brand and model number of the LCD TV would also have a 'say' on the alternative connection.
Suggested connection:
  • connect the Dish Network receiver to TV using HDMI;
  • connect the Dish Network receiver using composite VIDEO (yellow) and AUDIO (L & R / red & white) to the Protron PD-DVR100's SOURCE INPUT IN1 (VIDEO - yellow & R-AUDIO-L red & white);
  • connect the Protron PD-DVR100's VIDEO OUT (component) Y/G, Pb/B & Pr/R (green, blue & red) plus AUDIO OUTPUT to the TV using similarly colored INPUT jacks;
  • to watch Dish Network, set TV to HDMI;
  • to watch DVDs, set TV to Component Video (Video 1, 2, 3 or whatever is designated by the TV as component video depending on brand & model of TV);
  • to record Dish Network, set TV as if to watch a DVD. On the Protron's remote control, press the INPUT button a couple of times to cycle through the available inputs; Tuner, AV1, AV2, AV3, DV (IEEE 1394) and disc to select AV1
  • the Dish Network channel/program should now be displayed on the TV even if the TV is set to the Protron;
  • insert a supported blank DVD and press RECORD on the Protron unit.
Good luck and thank you for asking FixYa.
Solution #2
Somewhat Helpful)
RixsFixes
Rank: Guru
Rating: 94%, 297 votes
Hi
You have to feed the signal directly to the DVD recorder itself. The DVD recorder will have its own tuner and you have to put the signal antenna directly into the DVD unit.
The only alternative is to swich one of your HDMI inputs on your TV to an output. The problem with this is your TV will only output the signal you are watching (if the TV even has this capability and many do not).
Therefore your signal from the dish network must first be sent to the DVD and then output from the DVD to the TV, It sounds as if you may have it wired the other way round from your description.
Hope this helps. Please do rate this answer. Many Thanks.
Popular Solutions for Protron PD-DVR100 DVD Recorder
Questions and Unsolved Problems for Protron PD-DVR100 DVD Recorder
Do you recommend Protron PD-DVR100 DVD Recorder?
Answer
Answer
There is the frozen Protron image and no power when I pug it in. The power will notcome on. This has... (More)
Answer
will not record. unit says failed to stop current recording
Answer
I do not hear the dialogue voices with my Protron DVD recorder. All background noises can be heard... (More)
Answer
I have a protron pd-dvr100, dvd recorder - how can I get the set up mode to appear on an old tv set,... (More)
Answer
on my protroiq pnt300x it will load then say error or uploaf disc and it wont
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
