Question about Philips GoGear HDD1830 MP3 Player
No playlist found
Last night I synchronized playlists to my philips hdd1830/17 with Windows Media Player. All the songs show they downloaded in the main list, but my playlists are showing 'no playlist found' or there are only 2-3 songs under the playlist. It worked before this, but I'm not sure why it's not working now.
  • Anonymous Dec 13, 2007
    when I sync it says it's syncing but nothing on the Go Gear
  • Anonymous Dec 20, 2008
    Resyncing did not work...
  • 8,596 Answers
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
Posted on Feb 19, 2008
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
I cannot figure out how to make playlists and store them on my Sony mp3 player. I have workout music and study music and I cannot figure out how to make them so I can listen to the playlists separately.
The easiest way (though tedious when you start) I found was to just sync all my music, etc. through Window Media Player, then open the Walkman in Windows Explorer. Open the music folder and create a file for the music you want on the playlist. Copy all the songs you want the select the songs in the file, right click and create a playlist. Double-click on the playlist and put them in the order you want them. Click OK. Whan you disconnect the walkman, your playlist will be there. This is the only way I have found to actually have my playlist show up in the Playlist feature on my Walkman in the order I want the songs.
Oct 10, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlist on go gear vibe
Using Windows Media Player 11 ?
Right click in the head of the WMP11 page: in Tools > Options... > Player : select "Keep the player on top ..."
Sep 11, 2009 | Philips Audio Players & Recorders
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
Aug 29, 2009 | SanDisk Sansa e250 MP3 Player
How do I create playlists?
The manual, etc is available at www.p4c.philips.com
You will have to, unfortunately, set up your Windows Media Player for Auto-Sync (has definite drawbacks - inclduing: adding songs, pictures, etc that you DON'T want into the GoGear). Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
Nov 23, 2008 | Philips SA5125/37 MP3 Player
Menu
These directions only apply to the Philips SA6045/37:
It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
If you ask me, it's not worth it, but here's the procedure:
  1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
  2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
  3. Click on the Sync tab.
  4. Click on “Sync settings” or “Set up sync”
  5. In the pop-up window, select the playlists that you want to sync
  6. Click “OK”, the sync will start automatically
Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
-Tha Mp3 Doctor
Sep 12, 2008 | Philips GoGear Flash MP3 Player
How to save playlist into go gear
This GoGear REQUIRES that you use Windows Media Player 10 - you must uninstall your Windows Media Player 11 and rollback to version 10.
Once you have done that, the instructions with pictures are in the manual which can be found at: http://www.p4c.philips.com/files/h/hdd6330_17/hdd6330_17_dfu_aen.pdf
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
Apr 13, 2008 | Audio Players & Recorders
Philips GoGear HDD1830 MP3 Player Logo
367 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
