Are you sure you have the right code numbers? A search on Google produced no such error. What is the camera name and model?Are you sure you have the right code numbers? A search on Google produced no such error. What is the camera name and model?
You can't post conmments that contain an email address.
I figured it out. On the Manual page it states "Memory Card Up to 1 GB." I had a 4 GB in there and could never get it to work. I replaced it with a 1GB card and it is working fine now. Hope this helps. I have been messing with this for a while.
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that : Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
The "E50" error code indicates formatting a SD card has failed.
Solution
To clear the "E50" error, try performing the following procedure.
1. Try using another SD card.
If you have another SD card, try loading it in the camera.
If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the SD card for errors.
Use ScanDisk to check the SD card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the SD card on the computer before you check the SD card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card.
Follow ScanDisk's on-screen instructions to solve the problem.
The "E30" error code indicates reading/writing data on a SD card has failed.
Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data.
Solution
To clear the "E30" error, try performing the following procedure.
3. Format the SD card with your camera
Try to format the SD card with your camera.
Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card.
Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors.
If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Solution
Solution
Solution
Solution
Solution
