I have just ordered two new convergence IC's for my Pioneer SD-533HD5, rear projection TV and I...
(More)
I have just ordered two new convergence IC's for my Pioneer SD-533HD5, rear projection TV and I would like to know how to proceed to complete the repair. Thank you in advance for your support.
Where are the convergence IC's located and what is the recommended procedure to accomplish the above...
(More)
Where are the convergence IC's located and what is the recommended procedure to accomplish the above mentioned task? Thank you in advance. Adrian Vlake
the guy that im getting the tv from said something needs soldiered on the on/off switch it's a...
(More)
the guy that im getting the tv from said something needs soldiered on the on/off switch it's a pioneer 533hd5 53''
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you...
(More)
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you turn it off you need to wait an hour before turning it on again or it will blow a fuse. The fuse is easy to change, but what's the problem?
