Question about Toshiba Satellite P105-S6024 Notebook
NO POWER, CANNOT OPEN CASE
PC CHIPS A530 TM5600
Power failed, no charging, adapter fine.
Cannot open cade
  • Anonymous Feb 08, 2008
    My Armada E500 won't start with or without the power connected. If the thing start it dies after about 3sec.
  • utmr Mar 29, 2008
    Same problem here. Power cord OK. Now power lights on PC, won't turn on. HP won't admit this issue with the zv6000, only other models.
    Problem Solver:
  • 5 Answers
To Guest, who cannot start computer for longer that 3 secs, i have experienced this prob. myself. Actually it was not my laptop, but they came to me with this problem. Apparently the last time the laptop worked, the screen suddenly turned pink and then shut down. It would not boot for longer than a few seconds before shutting down again. I opened the laptop and removed the motherboard to find that soda had been spilled in two areas. One area of gunk was around the back of the ram, and the rest was throughout the 4 pins that connect the power cable to the motherboard. using some hot water/rubbing alcohol, and some q-tips, it fired up just fine!
Posted on Jul 20, 2008
  • 178 Answers
Bad Power jack on the motherboard and possiably a hairline crack on the board. I can help you please respond here.
Posted on Feb 10, 2008
A530 syntax a530 tm5600
take the old with you to your nearest eletronics shop and get a replacement charger
Oct 24, 2013 | Syntax AKA3000 PC Notebook
Alright so you need to pull all of the screws out on the bottom of the laptop. The casing will most likely require a little force due to any sealant that the company used if this is the first time opening it. you may also notice a little locktight on the screws that you have pulled out. You just need to run your fingernail or a flatheaded screwdriver around the edge of the panel and pry it off little by little.
Let me know if you need further directions or have other questions and I would be glad to do what I can.
thanks
May 12, 2008 | Averatec 3200 Notebook
A530 TM5600 LAPTOP
Can u please tell me your laptop's brand and model number?
Dec 06, 2007 | Computers & Internet
How do I remove/replace the ram modules on compaq persario V2000?
Just remove the power cord, remove the case, then you will see the memory inside the slots. Release the catches on both ends of the memory then pull it out.
Maybe one of the memory chips is bad or one of the slots is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 02, 2012 | HP Compaq dc5000 Small Form Factor PC...
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
My laptop was shut down, then when I was start it again it doesnt work anymore...What should I do?..please help me, aside from this those keyboards does not functioning correctly in their corresponding...
First thing you do to power your laptop on again try removing the battery and the charger complitly leave it for 10 sec without power then press the on off switch for 2 or 3 times without puting the power or batery later try not to put the battery and put only the power adapter and start your laptop dose it starts if yes good shut it down and put the batery in and start the laptop if its starting and leave it running for cuppul of hours and then again remove the power adapter and let it run the system with batery power if it stays on and fine you are ok and fine there was just a power dump but if it fails in any case like fails to boot with power adapter and so you have adapter issue need to be checked if dosent work with batery it self its a batery issue and needs replacement .
regarding the keyboard issue you can open the kay board and clean it with contact spray if posible.
Dec 12, 2010 | LG NB E500-JAP51A Notebook
Notbook Power adapter problem
Your power charger is fu.k.d up.  Get you a new charger on e-bay for cheap and try charging.  If that don't work, then the IC card charge port is fu.k.d up.  Open this puppy up and replace the thing.  You can find these parts on e-bay for cheap as individual parts or you can buy you a whole broken computer and use it for parts whenever parts on your computer start to fail.
Oct 31, 2009 | Computers & Internet
Acer aspire 5562 have no power and won't turn on
what repair shop does work at no cost?? ok first check the voltage from the power adapter, if you have or can borrow a test meter. i have seen these go bad and still seem to work!( incorrect amperage and- or voltage). or you simply have a failed motherboard .good luck !
Jan 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dell deminson 4600 fails to power up, power supply tested ok.
No beebs, no bueno. Unplug the power cord. Unplug the wide multi colored adapter from the motherboard and reseat it. make sure the other conntections are firm while you're down there and have the case open.
If you don't know what I'm talking about or don't want to crack open your PC then buy a new Dell and hae someone slave up your drive and transfer the information.
Jul 16, 2008 | Computers & Internet
Laptop no power A530 TM5600 PC CHIPS
if u have already checked the adapter then make a power drag trial, that is use the adapter with any other laptop of same voltage rating and if the lap works there is no problem with adapter as some adapters fail to deliver power at the time of consumption and gives correct multimeter reading.If the problem is with ur laptop surely u have to open the case,there after chk for dry solder and then chk power regulator ics ,chk short circuit of components etc
Toshiba Satellite P105-S6024 Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
