Question about Apple iPhone Smartphone
Iphone Call Ended
I have an Unlocked simFree iphone. Whenever I dial any number I get a "Call Ended" message and the call does not go through - this has started happening after 2 weeks of no problem usage - pls help
  • 7 more comments
  • Anonymous Dec 18, 2007
    my phone is fully unlocked but when i m dialing a number it dosent respond it gives call ended problem
    what to do
  • binnydf Dec 26, 2007
    i have a problem with my iphone whenever i m calling after few seconds my call ended and i got respond call failed what to do
  • Imranhr73 Jan 02, 2008
    Well same thing. I have the unlocked version and it worked well in every way for couple of weeks, but now though else works ok but the calls do not go through. I get a Call Failed and then Call Ended Message. Will appreciate if anybody could help.
  • peheng Jan 29, 2008
    OK i turned the caller ID on but is still not working, what should i do?
  • batu544 Aug 24, 2008
    hi , I am also facing the same problem ... I have restored my Iphone 2-3 times .. but the same problem is still there ...
  • Anonymous Nov 08, 2008
    Same issue here, worked great for 2 weeks then suddenly, it stopped working. All i get is call failed and call ended. Even for 911 calls. :(
  • danroberto Dec 09, 2008
    Same here. 2G iPhone, unlocked. I tried every solution I could find, but nothing helped... the only workaround for me is to take out the SIM, insert it to another phone, use it, and then put it back in the iPhone...
    This is crazy... especially because people can't reach me, and sometimes it's work related, important calls...
  • Anonymous Jan 21, 2009
    The same as you
  • dadon_yotam Feb 12, 2009
    my caller id was already on! and still very low signal!
GUYS - GOT THE SOLUTION
Very Simple. Just goto Settings - Phone - Show My Caller ID
And
Switch it to ON
It solved my problem and shall do yours too. It is caused by the carrier not allowing calls with the Caller ID not provided by the calling device.
imranhr73
Posted on Jan 02, 2008
Hi, I am using iPhone3G 8GB in Saudi Arabia. And was facing the same problem of not being able to make calls in low signal areas. But receiving calls was ok in those location. My problem was solved by switching ON my caller id. Thanks guys. Bye
Posted on Jan 27, 2009
    New Friend:
I have a problem in my i phone 4 i caller id is on but no solve problem of call ended now pls send me rply how to solve it ? And pls apple team give me update softwear bc no downld fb or more apps because 8.1 ios cmplsry but i have not update
Posted on Oct 06, 2017
    New Friend:
I love
Posted on Dec 02, 2012
    Problem Solver:
  • 5 Answers
I had the same "call failed" problem and it was solved by show caller ID "ON" in the settings.
Thanks.
Maven
Posted on Oct 24, 2008
Greate it fix my problem thanks
Posted on May 06, 2008
Though most of times the problem gets solved by switching the caller id on but sometimes the solution to to restroe the phone again
thanks Biny
Posted on Mar 13, 2008
  • 3 Answers
It is bec of phone have a big big problem in the hardware go and replace your iphone no more solution dead,,,,...
Posted on Jan 03, 2008
  • 47 Answers
My phone seems to do that sometimes, normally it a network issue, coz i have had it happen on my windows mobile.. u may want to do a soft reset and see if that sorts it. Else a full restore maybe needed.
Hope it helps
Z33m
Posted on Dec 07, 2007
HOW DO I DELETE VOICE MESSAGES WITHOUT LISTENING TO THEM ON IPHONE 4G
I don't believe voice messages are held on your iPhone itself.
Voice Messages are held by the Carrier you are connected with. Usually you dial the voice message service and delete the recorded messages at their end.
I asked my carrier to turn off the Voice Message service because it became a pain to deal with. That way I can see on my iPhone who has called and call them back if I want.
The iPhone is either a 4 or 4S. There is no 4G
4G is currently the fastest network speed that the phone carrier puts out. The previous one was the 3G network.
Cheers
Mar 03, 2015 | Apple iPhone4 4G iPhone 4
I installed acier theme in my iphone 4.and now the dial pad does not respond to any other numbers except *,0,1 and 2..please help.
I have the same problem but i got it fixed.
Just follow these steps,
1. Borrow another mobile phone from anyone close to you and have a miss call on your iphone.
2. Obviously, you will see a missed call on your iphone. Slide the notification to call back.
3. Once you see the call back signs (mute, keypad, speaker, add call, facetime, contacts) quickly press the home button.
4. If you successfully get into home screen, go to settings menu and turn off your screen lock (SETTINGS>GENERAL>PASSCODE LOCK)
5. And lastly, uninstall that theme and never use it again!
HOPE THIS HELPED YOU! (^^,)
Apr 17, 2012 | Apple Iphone 4 - 16gb - White gevey...
I upgraded my iphone and not recognizing my sim card???
you need to talk to your carrier and get a new SIM card, it will not work w/o the appropriate card. I had the same issue when moving from a 1st gen to a 3Gs and ended up going to the store... )-; hope that helps.
Jul 08, 2009 | Apple iPhone Smartphone
IPhone 3g power and volumes buttons are not working
You need to repalce the volume buttons, you can send you iPhone to Dr Cell Phone Repairs they do all kinds of iPhone 3G Repair . This repair should cost you only $74.99. For more information visit www.drcellphone.com
Jan 04, 2009 | Apple iPhone 3G Black Smartphone
Problem with sending emails on the iphone
What email provider are you using.
Also check who is your incoming mail server but the best way to do this is to delete your account and register it again on iPhone push mail.
Thank you, Apple Care Technical Support
Jul 02, 2008 | Apple iPhone Smartphone
I phone has incorrect own phone number
try out with this,
add the country code at the first of your contact number.
Feb 11, 2008 | Apple iPhone Smartphone
Cannot dial out
if u installed some foolish applications like cylay and kate remove them using installer or cydia. then restart the springboard or iphone. it will work (venusilicon@gmail.com)
Jan 21, 2008 | Apple iPhone Smartphone
Dialing + SMS returns to home screen
the turbosim you have is pre-programmed to work with uk networks, to solve this problem you'll have to purchase another pre-programmed turbosim that will work with your brazilian simcard..........check ebay!
Jan 14, 2008 | Apple iPhone Smartphone
Can't make calls
Plug into itunes,and click the restore button when the iphone pops up.
Jan 09, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
5,250 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
