Laptop no power A530 TM5600 PC CHIPS
No battery charging or power to machine - adapter OK.
Probably a dry joint but case resists all attempts to open it.
  • caraka Nov 27, 2008
    Same problem, which I know is a dry joint where the adapter plugs into the case. I simply cannot get the case open enough to get at the joint with a soldering iron. Any tips?
If u have already checked the adapter then make a power drag trial, that is use the adapter with any other laptop of same voltage rating and if the lap works there is no problem with adapter as some adapters fail to deliver power at the time of consumption and gives correct multimeter reading.If the problem is with ur laptop surely u have to open the case,there after chk for dry solder and then chk power regulator ics ,chk short circuit of components etc
Posted on Dec 09, 2007
A530 syntax a530 tm5600
take the old with you to your nearest eletronics shop and get a replacement charger
Oct 24, 2013 | Syntax AKA3000 PC Notebook
NO POWER, CANNOT OPEN CASE
Alright so you need to pull all of the screws out on the bottom of the laptop. The casing will most likely require a little force due to any sealant that the company used if this is the first time opening it. you may also notice a little locktight on the screws that you have pulled out. You just need to run your fingernail or a flatheaded screwdriver around the edge of the panel and pry it off little by little.
Let me know if you need further directions or have other questions and I would be glad to do what I can.
thanks
May 12, 2008 | Averatec 3200 Notebook
A530 TM5600 LAPTOP
Can u please tell me your laptop's brand and model number?
Dec 06, 2007 | Computers & Internet
Battery not charging
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 21, 2013 | Dell Inspiron N4030 14" Dual Core 2.13GHz...
Toshiba Laptop no longer charges battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 07, 2012 | Toshiba Satellite L555DS7930 Notebook
Power cord issues due to moving it while plugged in
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 02, 2012 | Sony VPCF13UFX/H PC Notebook
My hp DV5 not charging and the adapter is ok.if I put adapter into itthe light at the charging will on but it will not charge.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jun 25, 2010 | Computers & Internet
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
My HP pavillion ZD8000 laptop will not operate on mains power. To recharge the battery the machine has to be upside down. There would appear to be a loose connection wher teh mains adapter plugs in to teh...
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 10, 2009 | Computers & Internet
Bad Power jack on the motherboard and possiably a hairline crack on the board. I can help you please respond here.
Dec 06, 2007 | Toshiba Satellite P105-S6024 Notebook
Open Questions:
Computers & Internet Logo
324 people viewed this question
Alun Cox
David Payne
David Payne
