Question about Nokia 3230 Cellular Phone
Time duration not showing ahen making an active call
Time is not showing in the display when i am making a call
  • Nokia Master
  • 456 Answers
Go to setting then call setting you will find ther an option time duration turn it on and done
Posted on Dec 06, 2007
Samsung schf309
first make sure that you have set the time on your phn accurately and then chek the settings regarding calls. allow them to show the call duration. thank U!
Sep 22, 2013 | Cell Phones
I want to use this TV as a digital slide show, but I am unable to get the slideshow to repeat, or to change the length of time a slide is displayed at a time. Does anyone know of a work around on this?
I am not familiar with this brand. I have worked with another unit that had no options for controlling repeat or duration.
To fake it you could load the images over and over again. In other words if you had three images A, B, and C that you wanted to play over and over put on your thumb drive (or SD card) A,B,C,A1,B1,C1,A2,B2,C2,... where file A, A1, A2, etc. are all copied of the same file.
Do you want the duration to be longer or shorter? If longer, consider arranging the files: A,A1,B,B1,C,C1,A2,A3,... effectively doubling the duration of each image.
Finally, one other option. Invest in a $35 ChromeCast. I have one and it will easily play a PowerPoint from the Chrome browser over the wireless network to a remote display.
Sep 10, 2013 | iSymphony LED19iH55D 19 TV
MY ACCU CHEK (ACTIVE) GLUCOMETER IS NOT WORKING AND SHOWS ERROR 5
"E-5" in the display means the codekey is incorrect or your test strips have expired. Make sure the time and date in the meter are correct.
Mar 01, 2013 | Accu Chek Active Glucose Control Solution
How to set the defrost duration on a timer
Copy following link for defrost timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
There are 2 general types defrost timers.
Time activated - Time terminated
Time activated - Temperature-pressure terminated, with timed termination back-up
Here is basic image:
http://waterheatertimer.org/images/8145-work-image.jpg
Rotate dial until current time lines up with pointer, insert tripper pin on outside edge of dial to select defrost start-time, move defrost duration tripper on inner dial to set termination time.
Each defrost timer is slightly different:
If timer is time-terminated, then wiring follows certain diagram.
If timer is temperature-pressure terminated, then different wiring diagram is used.
Nov 11, 2012 | Paragon 8145-20 Defrost Timer
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
May 11, 2011 | Sony Handycam HDR-CX160 Camcorder
It keeps turning itself off! How do I keep it going 24/7?
Well that seems like a waste of energy.
Anyway that is your problem.
The Power/Sleep button has a dual function: Power ON/OFF and Sleep.
A short press will turn the timer on and you will see numbers like 90, 75, 60,...10, 01. pPressing again will cycle to the next sleep duration. If your radio has a short duration timer it will seem that it is turning itself off.
To activate a normal Power up, your first press should last longer (I cannot tell you how long, you will have to try it on your own.) You should not see the timer durations, just the frequency of the station its was last tuned to. In addition, no loudspeaker should be displayed at the lower right corner.
Sep 03, 2010 | Grundig S350 AM/FM/SW Radio
Im using n73 mobile,ijust want know information about call summery duration during call..
Please follow below steps
To check the call duration of your incoming
and outgoing calls, press Menu , and select Applications >
Log > Call duration
To set the display of the call timers while a call is active,
select Applications > Log > Options > Settings > Show
call duration > Yes or No.
Thank You
Aug 11, 2010 | Nokia N73 Cellular Phone
How to delete call duration in nokia 3110
Hi
You cannot delete your call duration,you can only stop it from displaying on the screen while you are making a call or after you have made a call.
To stop display of call duration while making a call,follow this step
From menu click on settings scroll to call settings and click on it scroll to call duration display click on it and select OFF.
To stop display of call duration after making a call,
From menu click on settings,scroll to call settings and click on it scroll to summary after call,click on it and select OFF
Thank you for visiting fixya
Mar 26, 2010 | Nokia 3110 Cellular Phone
I need a program of cpu scheduling using C++ please help me out it consit of FCFS,SJF and RR..
// crt_clock.c // This example prompts for how long // the program is to run and then continuously // displays the elapsed time for that period. // #include <stdio.h> #include <stdlib.h> #include <time.h> void sleep( clock_t wait ); int main( void ) { long i = 6000000L; clock_t start, finish; double duration; // Delay for a specified time. printf( "Delay for three seconds\n" ); sleep( (clock_t)3 * CLOCKS_PER_SEC ); printf( "Done!\n" ); // Measure the duration of an event. printf( "Time to do %ld empty loops is ", i ); start = clock(); while( i-- ) ; finish = clock(); duration = (double)(finish - start) / CLOCKS_PER_SEC; printf( "%2.1f seconds\n", duration ); } // Pauses for a specified number of milliseconds. void sleep( clock_t wait ) { clock_t goal; goal = wait + clock(); while( goal > clock() ) ; }
Mar 22, 2009 | Computers & Internet
Nokia 6600 - Active Call time is not visible.
I also had the same problem. Previously It was OK when I hard formatted my 6600 (by keeping Green, 3 and * keys pressed and switching on the phone from OFF state). I am afraid, after like 10 months, this problem is back again, and, this time...... its not going away after even the hard format. May be you can try it.... It worked the first time for me dude. Good luck.
Dec 13, 2006 | Nokia 6600
Nokia 3230 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
