D-Link AirPlus DI-524 Wireless Router
Problem for D-Link AirPlus DI-524 Wireless Router
Phoblem with 524-up
By LPWHITE on Dec 06, 2007
hi,
evreytime I put 192.168.0.1 into my browser it takes me to webpages
my friend does exactly the same but his wirless router box pops up straight away why won,t mine I have a problem with gb thieves
Please help me anyone plzzzzzzzzzzzzzzzzz
Comments:
Dec 06, 2007
- I need to lock this thing as it is wireless but just found that out
Thankyou
Dec 07, 2007
- Thankyou for your reply but
I forgot to tell you I am a novice with computers and have no ideah about computers
I have loked on the base of the model and it does say 192.168.1.1 but when I put into browser it just lists webpages
I have no ideah how to do "dos" please can you explain in laimans terms so I can get this thing done
P.S
I am very impressed with your knowledge of computers I only wish I were as knowledgeable
Thankyou in advance
Lindsay
Solution #1
posted on Dec 06, 2007
Somewhat Helpful)
pasha19
Rank: Guru  D-Link Expert
Rating: 86%, 772 votes
All wireless router manfacturers do not set their devices to the same gateway address so the 192.168.0.1 may not be accurate for your router. Can you identify the router's manufacturer and model number? Without that assuming you are on a windows computer you can open either a DOS Prompt or Command Prompt depending on the version of windows you are running. From that window issue the command ipconfig (it may require some operands and there may be multiple connections appear). Generally look for a connection probably with an IP address beginning 192.168.?.? and record the default gateway also probably a 192.168.?.? address. This may then be utilized like your friend to access the configuration for your wireless router. You may require an url like https://192.168.?.? or http://192.168.?.? where ?.? is from the default gateway address above. In addition you will probably require a UserID and Password that if unchanged can be gotten from the manufacturer's documentation or possibly reset using the manufacturers documentation if it was changed and is unknown. The manufacturer and model information along with the information for the wireless network adapters accessing router will be necessary to find a suitable security scheme to "lock" this device for secured access. Besides encryption schemes routers sometimes support using MAC addresses from your specific network cards to limit devices they will communicate with. These decisions need to be made after the additional information is identified.
Comments:
Dec 06, 2007
- Sorry just noticed the DI-524 model number. There appear to be 5 revisions for this particular model please review the indicated link and determine the specific revision for your router.
http://www.dlink.com/products/support.asp?pid=316&sec=0#quickInstallGuides
Also try to gather the manufacturer and model number of the various wireless adapters (cards) you expect to communicate with this device.
Thanks
Dec 07, 2007
for general wireless security (how to lock a wireless router) see
http://www.fixya.com/support/t281214-wir...
Dec 08, 2007
- Using a computer wired to the router with an ethernet connection, if possible with the router turned on
Please try the following (assuming Windows XP)
Click START then All Programs then Accessories then Command Prompt.
In the open window type -- ipconfig --- (8 letters) and press enter
There will be a display of adapters, subnet addresses and default gateways Please report those back as a comment to your initial question and I will attempt to provide a next step.
Thanks
Dec 09, 2007
So we can access the router to configure it -- the web pages you claim to see -- that is good -- sorry I was so slow in understanding that..
Step 1 use the link below-- match the pictures to the label on your router and get the revision A, B, C, D, E for your router so we can download the associated link. This will allow us to have matching copies of the user guide for your wireless router.
http://www.dlink.com/products/support.as...
Step 2 - I need to know about your wireless adapter. If it was built into your computer by the manufacturer can I get the manufacturer and model number of your computer? If it is an add-on device can I get the manufacturer and model of the device?
With the user guides for your router adapter and your wireless adapter (or computer telling us about the wireless adapter) we can choose an encryption option that will work with both your router and your wireless adapter.
Thanks for your efforts thus far.
Was this helpful?
Yes
No
Solution #2
posted on Mar 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
secured my internet
Popular Solutions for D-Link AirPlus DI-524 Wireless
Questions and Unsolved Problems for D-Link AirPlus DI-524 Wireless
Do you recommend D-Link AirPlus DI-524 Wireless Router?
Answer
Answer
modem isn't not working, but all lamps are burning, i don't know what is the problem, can anyone... (More)
Answer
how to setup up a access/bridge to connect 2 routers. I want to make a second router to receive a... (More)
Answer
DI-524 Wireless Rourter D-Link To connect my laptop wireless I have to change the port. To use it on... (More)
Answer
Using D-Link wireless router unencrypted and want to encrypt with the WPA protocol that it uses. The... (More)
Answer
Ihave xpdesk top computor not connected, and have a laptop vista connected to wireless router how... (More)
Describe your Routers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
