I just got a new Danby ddr7009ree for one day- the continuous drain hose is attached, but the bucket still fills and shuts the unit down. Only very small amount of water came out from the hose.
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Danby DDR6588EE Dehumidifier
Danby ddr7009ree - the continuous drain hose is attached, but the bucket still fills and shuts the...
(More)
Danby ddr7009ree - the continuous drain hose is attached, but the bucket still fills and shuts the unit down
there is no water being taken from air. No water in reservoir. fan works, filter is clean This...
(More)
there is no water being taken from air. No water in reservoir. fan works, filter is clean This machine was purchased June 14, 2008 and the customer service is ridiculous. It may be a year old but it was only used for three months.
The buttons on the control panel, don't appear to function at all. When the system is initially...
(More)
The buttons on the control panel, don't appear to function at all. When the system is initially plugged in the fan and light come on but no other functions are working and the system collects no water.
the dehumidifier will run for short time, then it will shut off and indicate that the tank is full,...
(More)
the dehumidifier will run for short time, then it will shut off and indicate that the tank is full, even with just a few inches in the the bottom of the tank
