DISC SPACE HOT I RECENTLY BOUGHT A GAME AND WHEN I HAVE INSTALLED IT IT HAS SAID THAT I HAVE NOT ENOUGHT DRIVE SPACE I HAVE GOT ENOUGHT SPACE BUT IT SAYS THAT I HAVNT WHAT SHALL I DO THE GAME I WONT TO PLAY ON IS COMMAND N CONQUER AND IT SAY THAT U CAN RUN IT WINDOWS 95/98 IS THIS THE PROVLEM
    Novelist:
  • 233 Answers
As I understand you have XP or Vista.
You want to run a program that was created for Windows 95/58.
Try the simple things first...
Right-click on the program icon, select Properties, select the Compatibility tab, then put a check mark in "Run this program in compatibility mode for:" Select Windows 98.
That should do it.
Posted on Dec 07, 2007
The problem may be that you have too much space (sounds dumb I know) Windows 95/98 originally did not support drives as big as we have now, resize your drive down to less than 2GB and retry the install, or create a partition for the Game that si smaller. If you are running XP/Vista, you may be able to resize with disk Management, otherwise there is third party software like Partition Magic...
I hope this helped.
What makes my DVD ram not to open
The DVD drive may be faulty or it is not makeing proper electrical connection. Try removing the DVD drive and reconnevting it again.
If there is a disc in the drive, use a straighten paper clip and insert it into the tiny hole in the drive tray. Push the paper clip in gently and the tray will unlock and pop out. You can then pull the tray out until you have enought space to remove the disc.
Feb 06, 2012 | Toshiba Satellite A100-S8111TD Notebook
Hi my name is chris and I have a game that I bought last year and i am 11 years old. when i got this there was no scratches but when my family was moving and i was at school at that time my brothers were...
It is possible that your game is scratched up enough that you can't play it directly on your xbox 360... BUT you might still be able to play it is you can save it to your Xbox 360 hard drive. You might need to try it a few times to get it to read and work but try following these instructions for installing the game from your CD directly onto your Hard drive. You will still need to have the CD in your Xbox 360 to play but it will be reading from your hard drive if you can install it. Good luck:
To install a game on your hard drive loadTOCNode(2, 'moreinformation');
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press the Y button on your controller.
  5. Select Install to Hard Drive.
  6. A progress indicator appears while your game is being installed on your hard drive.
Note Installing an Xbox 360 game might take 12 minutes.
To play a game from your hard drive loadTOCNode(2, 'moreinformation');
  3. Select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
To delete a single game from your hard drive loadTOCNode(2, 'moreinformation');
  1. Insert the game disc for the game you want to delete from your hard drive.
  2. Go to My Xbox, and then select the game you want to delete.
  3. Press the Y button on your controller.
  4. Select Delete from Hard Drive.
To delete multiple games from your hard drive loadTOCNode(2, 'moreinformation');
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Select Hard Drive.
  4. Select Games.
  5. Select the game you want to delete.
  6. Select Delete.
To clear space on your hard drive loadTOCNode(2, 'moreinformation'); If there is insufficient space on your Xbox 360 hard drive, you will receive the following message:
Not enough space to install this game. It needs [space needed] free space to install. Do you want to clear space? (YES/NO) Click YES to view a list of games that you can delete. After you clear enough space on your hard drive, you can install the new game.
Jul 20, 2011 | Video Game Consoles & Games
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  4. Press Y on your controller.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Jul 18, 2011 | Microsoft Xbox 360 Console
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Notes
Jul 17, 2011 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Printer will not install
Hello. Thanks for choosing Fixya! Click on your start button and then on printers and faxes. Look and see what other printer drivers you already have installed. Delete any that you no longer need and THEN install your new disc. Regards, Joe
Nov 12, 2009 | Office Equipment & Supplies
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
New Game I Bought
BAD IDEA to post youe email address !!!
May be a video card issue or directX not being at latest version.
What are the specs for you PC?
The min spec to run this game is as follows
Minimum System Requirements
OS: Windows® XP, OR Windows Vista™
CPU: Athlon™ 1500+, Pentium® 1.5 GHz, or faster (2200+ or 2.2 GHz for Windows Vista™)
RAM: 512 MB (1 GB for Windows Vista™)
Disc Drive: DVD-ROM
Hard Drive: 8 GB of uncompressed free space
Video: 128 MB video RAM, DirectX® 9.0c-compatible
DirectX® 9 Minimum card: ATI® Radeon® x700 Pro and above
DirectX® 9 Minimum card: NVIDIA® GeForce® 6600 GT and above
Sound: DirectX® 9.0c-compatible
Input: Keyboard and mouse
if your system is not at least at this spec the game probably will not run
Jul 03, 2008 | Video Game Consoles & Games
Prostreet need for speed
get your finger outta your arse
Jan 20, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
