Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi VS-50603, input is gone
After a recent power outage, when I turned the tv back on I had only Ant-A and Ant-B. I lost the inputs. I need the inputs to play my vcr and Nintendo Wii game. Can someone help me to reset the tv and get the inputs back?
  • michelepage Jul 29, 2008
    yes we currently are having the same problem. any solutions will help.
  • Anonymous Feb 10, 2009
    Thanks newyorkjeff!
    I had the same problem after coming back from
    vacation. My husband had unplugged everything since we were going to be
    gone a week, we came back and couldn't get any picture except through
    the pip and the only inputs we could get were A and B instead of the usual options. I unlocked the input 1 and everything is back to normal!
    Thanks a bunch. :)
Happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Posted on Dec 21, 2007
Thanks newyorkjeff, I just had the same issue as the OP, and switching home theater to "off" fixed it.
I looked up home theater in the manual afterwards, and it does say that the home theater option "locks the antennas to Ext-1." Would have found it eventually, but this thread saved 4 hours of my life. Thanks.
Posted on Sep 01, 2008
Thank you newyorkjeff, it really solved my problem.
Thanks again.
Posted on Nov 01, 2008
    Scholar:
  • 87 Answers
There is a menu where you can add a device but Mitsubishi makes it difficult without an owners manual. E- mail Mitsubishi technical assistance at www.mtech@mdea.com they will answer your question.
Posted on Dec 07, 2007
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
Rf but no video and sound
S-Video Hookups
Note: The S-Video cables are not compatible with the redesigned Super Nintendo. They are sold separately at most retail locations as well as nintendo's Online Store.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV or VCR.
Place the black end of the S-Video Cable into the S-Video IN on the back of the TV or VCR. Connect the red end of the cable to Audio IN Right.Connect the white end of the cable to the Audio IN Left. Use a slight twistingmotion when inserting the each cable and ensure the cables are firmly pressed into the input.
Connect the rectangular (gray) plug of the S-Video cable into the multi-out connector on the back of the Control Deck.
After system is connected to the TV or VCR:
Insert Game Pak fully into the Control Deck.
Plug the controller(s) into the front of the Control Deck using the left-most port for one-player games.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press Play, make sure the movie appears on your TV, then press Stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward the Game Pak).
Turn on the VCR and locate the input select. It's often called: input select, AUX auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play! To record video games, set the system up to play games as usual, then insert a video tape and press Record. It's that easy!
Dec 27, 2011 | Nintendo Super NES Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
My nintendo nes works fine but when i put in mario/duck hunt i can choose which one i want to play and when i choose mario it gose to the next screen where you choose 1 or 2 players and this is where i...
Will try cleaning the game packs out with quips and vinegar try connecting it to a DVD player or a VCR then.
Installation Steps:
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the VCR.
Press the Power button on the front of the Control Deck.
Apr 14, 2010 | Nintendo NES Console
My Ant A Input Not Working
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
Aug 06, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
627 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
