Bush RF6694D TV Over-Underscan
I bought this 18months ago and it seriously underscans (by 2" vertical and 2" horizontal). I noticed more since I can tranfer the pictures to my PC and can see what I am missing.
The "ticker" on BBCNews24 is unreadable. On SkyNews I can just about see it. I didn't realise I was missing so much as the side aswell until ITV News went widescreen and I couldn't even notice any difference.
There is no facility to change the settings from any of the on-screen menus. I presume there is a hidden "installer menu" somewhere>
  • StuartPlymth
    StuartPlymth Dec 09, 2007
    Thanks for replying, not sure what B+ is (sounds technical). There is certainly no shrinkage/expansion due to brightness changes. It's a very stable and good picture.
    The TV set I had before had buttons so that you could adjust the vertical and horizontal setting of what was visable on the screen. It's something similar I need for this one. However, everything seems to be done via on-screen menus and I can't find anything that does those functions. A friend suggested that perhaps there is a hidden function within the menu which would normally only be available to a TV Engineer who knew how to find it.
    Hope you can help.
  • StuartPlymth
    StuartPlymth Dec 10, 2007
    Most manufacturers seem to have a "Service Mode" within their configuration menus. I'm sure Bush must do the same. Does anyone else have further information?
  • 138 Answers
No there is nothing hidden menu in that. If the menu is available then it must be visible. I think you should take help of the Manual to set your configuration. And might be an TV Authorised person can solved it.
Posted on Dec 09, 2007
My bush tv is 2 years old and has 2,sometimes 3 vertical lines running down middle of screen.what could be the problem please.x
Hi Roberta.
its the horizontal circuit fault in the Tv. Look back from the Yoke socket and from the two red and blue terminals and you you will get into the horizontal circuit
uusually its components starts with the number 4 at the Tv chassis
resold the components there good and this problem will be fixed
as its a solding loss or track cut at the tv chassis
you need to be familiar with tv repair to do this or get technician to fo thid for you
May 06, 2015 | Bush Televison & Video
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
My Sony KP-51HW40 is underscan!
If you have already changed the aspect ratio on your TV, then change it on your cable or Sat box. Your TV appears to be operating normal.
Jun 17, 2012 | Sony KP-51HW40 51" Rear Projection...
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
My bush tv has a light purple circle in the middle with a blue then green halo.It turns red to blue in the centre,is it worth repairing.
has any full tv image? if not is a vertical and horizontal circuits defectives, send to repair
Nov 22, 2009 | Bush 5693D 24" TV
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
TV screen dislay partial horizontal beam
you had a problem on vertical section of your tv, if can fix it ,change the 100/50 volts capisitor on .vertical section or else all capasitors in vertical section
Oct 07, 2008 | Televison & Video
Bush RF6694D TV (Service Mode)
Hi.
I may be able to help you but I need to know the chassis number of your tv set.
This will be on the back of the set on the same label as the model number or if not there it will be on the main pcb.
It could start with AK, or PT.
http://dysonmanuals.inc.io/
Chris..
Dec 14, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
