Question about Sony PlayStation Portable (PSP) Console
Psp how can i fix my psp,it's bricked and theres no recovery mode..... help....
  • Anonymous Mar 17, 2008
    THE GREEN LIGHT IS NOT COMING ON AND SOMETIMES IT GOES OFF WHILE PLAYING
  • Anonymous May 04, 2008
    The Best way to fix a problem like this is to use a PSP Repair Guide.
    You can find a good one here:
    www.PSPRepairsGuide.com
    Problem Solver:
  • 32 Answers
Send it to sony to get it repaired or use a pandoras battery with a pandoras memory stick with an unbricking option on it... there is much much more detail to this which I wont explain here just look it up and this will get you started.
Posted on May 04, 2008
  • 32 Answers
Here watch this you tube :
http://www.psprepair.net/tag_fix_my_psp.html
Posted on Dec 06, 2007
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
Psp power indicater lights up green but does no turn on.
Hi.
It's probably bricked (dead). We need to know what's your last activity before it bricked. Mostly, bricked PSP is due to interruption during firmware update. Or when you install a CFW (Customized Firmware) by using ChickHen.
If your PSP is the slim type, you need to know what type of Motherboard it has. You will be lucky if you don't have a PSP with TA088v3 MoBo. Since you can no longer turn on your PSP, you will have no chance knowing the MoBo. But this procedure below is worth the try;
1.) Turn off your PSP by pressing the power button at least 10 seconds and green light is gone. 2.) While turned off, do one of the following until you boot into Recovery Mode;
a.) press the "R" button and hold it while pressing the power button. b.) press both "L" and "R" button and hold it while pressing the power button.
3.) If you are successful booting your PSP into recovery mode, google on how to recover your flash0 file...
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
My psp got switched off when i formatted. when i switch on, it shows a blank screen. please help!
I guess we have a BRICKED PSP here.
Well, if you got a PSP Board that can be recovered from bricking, try doing this;
1. Totally turn off your PSP by removing your battery and putting it back. 2. Press and Hold "R" button while switching your PSP on. 3. If Recovery Menu appears, click the recovery boot option.
If there is no Recovery Menu, your second option is to try Unbricking your PSP using PANDORA Battery and a Magic Memory Stick.
May 20, 2011 | Video Game Consoles & Games
Ok so my psp is not turning on the battery is fully charged the green light turns on for acouple of seconds then turns off any tips
Hmmmm... I guess we have a bricked PSP here...
First, I should be right with this - either you tried to install a Custom Firmware (ChickHen) or you were updating and something went wrong.
In order to UNBRICK your PSP, we need to know the following;
1. Your PSP make (Slim or Phat) 2. Your PSP Motherboard (if available)
However, try doing this as this might work if you have a Motherboard that can be recovered from bricking;
1. Press and hold "R" while switching on your PSP. 2. If your PSP boots on into a "Recovery Mode", you're a lucky guy 3. Scroll down to "Run Program at /PSP/GAME/RECOVERY/EBOOT.PBP" and do the rest to recover your PSP's firmware.
Get back if you still have a dead PSP.
Mar 02, 2011 | Sony Video Game Consoles & Games
My friend delete the flash 0 and flash 1 file from the hard of psp so it work with balnk screen and green light for 40 s so how can i enter to the hard and put the file or restore the firmware "the...
If you are on a PSP 3000, you are screwed, PSP is bricked, and can NOT be fixed. If you are on custom firmware, on a fully hacked PSP 1000 or 2000, you can use HellCat's Recovery Flasher to restore the semi-brick. You have to get a Pro Duo > SD convertor, and get HellCats onto your memory stick, then run it from recovery.
Good Luck!
Jan 31, 2011 | Sony PlayStation Portable (PSP) Console
My psp 3002 is bricked now hot enter recovery mode
when psps are bricked..................connect to usb and delete everything on it. even all folders.
Dec 23, 2010 | Sony PlayStation Portable (PSP) Console
Psp Went Black
you bricked your psp.best way to know if thats a semi or full brick go to recovery mode then run your eboot recovery file
Aug 14, 2009 | Sony PlayStation Portable (PSP) Console
Picture won't show when turned on?
It sounds like your PSP has been bricked and you need to fix it with a pandora battery kit from www.pandorasales.com. The pandora battery kit comes with a memory stick that contains the program to recover your psp and install custom firmwares if you want and the battery places the PSP in service mode to allow it to be operated on by the program. You could try recovering your PSP by making sure its off. Then hold the right R trigger on the PSP and hold it while turning it on. If you see a PSP recovery menu then you can recover it without a pandora battery kit. It may take a few times before it enters the recovery menu, but note that all PSP's dont have them on there.
Jun 09, 2009 | Sony PSP (Piano Black)
Bricked PSP
sorry but the pandoras battery solution is the best one.
search youtube for a video that shows you haw to make your battery into a pandoras battery via hardmod. you will need one program but the video will show you.
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
PSP Bricked?
Brick has two signs
A. semi bricked - your are able to go in the recovery menu (open your psp and hold the right trigger in 5 seconds)
B. fully brick - u can't go to the recovery and not charging
A.semi- brick
  • Things you will need:
  • A psp and a pandora Battery
  • 1.first download this padora file http://www.megaupload.com/?d=U4I65Q7F
  • 2. go to recovery mode of your psp
  • 3. then press toggle usb
  • 4.format the memory stick
  • 5.put the padora files root of the psp
  • 6.put the pandora battery in the psp
  • 7.press the x button when you see a menu
  • 8.then follow the instructions shown on the screen on psp
  • 9.your done you can now delete the files!
  • congratulations!!
B.Fully bricked
  • Things that you will need:
  • Card reader/writter
  • Pandora battery
  • 1.download the pandora files that use in semi bricked
  • 2.use the card reader/writter
  • 3.fomat the memory stick
  • 4.place the pandora files in the root of the memory stick
  • 5.put the memory stick in the psp
  • 7.press X button when u see a menu
  • 8.follow the instructions
  • 9.done u can now delete the files!
THATS ALL!!
Dec 04, 2006 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
