Question about Hitachi Performa CP-RS55 Multimedia Projector
How do you change the lcd panels on a hitachicrr-s55 projector
I have blue blur on the right hand side of the screen it gets worse as the projector gets warm i believe this is an lcd problem i have two of these projectors the other one has a u/s power supply so i intend to use it for spares so i just want to know where they are situated and how do you change them if any of you could help it would be much appreciated.
Many Thanks
Eddie
  • 563 Answers
Hi Eddie
Rather take out the whole LCD unit with prism and replace it.
It is situated in the front of the unit , you can't miss it.
Tip : Don't try and replace only the faulty LCD - IT WILL TURN OUT A DISASTER if you have'nt done it before.
Posted on Mar 26, 2008
There is a blue/green light blur on the bottom right hand side of the tv
The problem seems like it is the optical block. When the optical block goes bad blurs will begin to develop on the screen, possibly in the a blue /green or purplish color. Once it begins it will only get worse and replacing it is expensive and impractical since you can get a better television for less money than the parts. Repair is an option, but it is only a short term solution to a problem that lies with poorly made parts that will inevitably fail again. If you are interested in repair check with your local TV repair company, or search eBay and craigslist for advertised optical block repair.
Jan 31, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony TV LCD screen blurred down one side when switched on and then after warm up appears to fix itself.
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Mar 24, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
Blue tint on right side of screen.
take it down turn it on the fan may be magnetizing the frame.you may also try running a magnet over the bulb to pull the blue back into its place
Oct 17, 2009 | Sony XL-2200 - LCD projector lamp
Two vertical blue bands on right side of screen, get worse as movie progresses, and black areas look really blue. Air cleaned entire projector per manual instructions. Also rotated both blue IN and blue...
with the projector off, remove the cover and unplug the blue lcd panel ribbon cable from the main board and reinsert it. you have to unlock the cable first (either the clip goes up or out, but do not force). if that does not solve the problem, you have a faulty lcd panel.
Sep 08, 2009 | Sanyo PLV-Z3 Multimedia Projector
Blurred side of projector
This is caused by misaligned lens and/or display panel (LCD or DLP). Recommend a trained tech to perform alignment.
Mar 08, 2009 | HP Digital Projector Vp6110 Multimedia...
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
Problem with picture on television
Are you talking about a TV set or a projector? If the former, is it a CRT or LCD or plasma?
Jan 05, 2008 | Computers & Internet
Blue on one side of the screen.
as a first step, check for dust and dirt in the optics of the unit, sometimes they can cause these kinds of problems. if not, Look at the filters attached to the blue LCD panel. If I remember correctly it has a dark "yellow" mirrored surface. I have had one go bad and give the same symptoms. It looked like it may have had an optical flaw that "captured" the intense light rather than passing it thru it. As time passed it got worse. The replacement filter fixed it.
Mar 24, 2006 | ViewSonic PJ1060 Multimedia Projector
Hitachi Performa CP-RS55 Multimedia Projector Logo
196 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
