Question about Refrigerators
GE Regrigerator "Profile" PSS26SHPA SS
I have a GE side by side refrigerator for over 2 years now. Recently I noticed that water is leaking from the freezer side and ice in building up in the freezer.
Could you advise me as to how to resolve this problem.
  • Watto62 Dec 15, 2007
    I checked the defrost drainage tube and found it to be clear.
    So the problem still exist.
    I would also like to add that the freezer seems to be cooling at a lower rate now. i.e it takes a longer time to cool and freeze things.
    Sergeant:
  • 288 Answers
It sounds like the drainage for the defrost water is plugged or obstructed somehow. The ice build up is left over water that is freezing due to the fact that it has not been channeled out properly and when the cycle comes back on it freezes.
look for the collection pan underneath the fridge, access the tube ending to there, blow some air through it. Compressed works best if you have access to some. Also I would advise doing this after the unit has been off for a short while, sometimes the plug will be frozen, so give it time to melt just in case. When you blow on the tube there should be no back pressure, this will tell you if the plug has been removed.
Posted on Dec 06, 2007
  • Rob Luna
    Rob Luna Dec 17, 2007
    Well, I am assuming the drainage pipe it all good as you have checked it for clogs and leaks. I would like to know if you can tell if there is water actually reaching the drain pan underneath the fridge. If so, you are in good shape. In regards to the slow cooling, what condition are your door gaskets? A bad gasket can cause moisture to build up inside the box, thus giving you excess water inside (condensation). Also make sure the fan is running at high speed, if not this will cause excess ice build up on the evaporator coil. I don't think this is the problem, but without looking at it ,I cant tell for sure.
Behind the bottom shelve is a fixture with the bottom light bulb and the bottom went. On each side of this fixture are rubber drains which connect to the drain on a 90 degree angle. This drain is under the a.m. fixture. The drains are cut in 45 degree angle in order to fit each other. The problem is where the the connecting ends i.e. the vertical drain and the horisontal drains meet are not glued together. i notiched however the clever people at GE know about this problem and solve it with a "TAPE". You either have to buy a rubber glue or tape it yourself.
Hope this will help.
Julius
Iceland
Posted on Oct 03, 2009
My 1 year old ge profile refrigerator has a serious leak problem from the refrigerator water filer. What should I do?
Check where the leak came from in the water filler, probably a pin hole will cause that. If you already located the leak then apply a small amount solvent or epoxy into it. You can buy solvent or epoxy from
hardware store. Look for a brand that is not harmful to human and especially use for water leaks.
You can do it so good luck.
Jul 03, 2011 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Leak on bottom of freezer on ge profile side by side 13 years old
maytag has several great models and absolytly worth it remeber u get what u pay for . and any fridge u buy get the extened warranty that way no worries for awhile
Mar 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Profile side by side refrigerator,model #GSC23LSRC SS
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE Arctica Refridgerator, PSS26MSRB SS, water leaking from tray, and other questions
ok first the water dispenser i would take out the drip tray and run a thin bead of black silicone to seal it there as to the turbo light getting brighter its because when you switch on turbo its running more power through the switch to the fan now to the fan early model fans were noisy i think ge redid them and if you contact ge you can get one of the newer fans hope this helps by the way loved the pics and mpeg that helps
Jan 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Dec 22, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
