Question about Acer Aspire L100 PC Desktop
Acer l100 cuts out for no reason
I have a new acer l100, and from time to time for no reason it just shuts itself off. it does it occasionally when i am surfing the net, and then last night i installed itunes for my new ipod and when i was trying to import cd's it cut out every time.
  • Pkhanal Dec 13, 2007
    I have the same problem. I tried to set Windows vista to factory settings but computer shuts down every time at the end of installation. I did it in a cooler environment, still doesn't work.
  • 55 Answers
I suggest to remove the program for itunes, i think it did make a mistake  to the operating sistem
Posted on Dec 06, 2007
Why does Acer l100 PC shut down?
You need to service you pc ar laptop. The cpu needs to get new thermal compound every 3 to 6 month's add me on facebook Nic fourie for complete guide to how the service your own pc or laptop
May 11, 2014 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
    this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
    May 14, 2010 | Acer Aspire L100 PC Desktop
    It keeps shutting off for no reason
    you should check fan processor, or check your power supply (you can borrow from your friend to try first, before you buy it to replace yours)
    Dec 19, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Acer l100 shut down
    You can buy a Laptop cooling pad for less than $40 from most any computer store.
    Oct 26, 2008 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    Over Heating Problem In Acer Aspire L100
    There are two solutions to this problem. First set the fan in the PC Bios to rub at full speed all the time. This was too noisy for me.
    Second, If you are running Windows Vista, you can adjust the Maximum Porcessor Utilization. From the Windows Control Panel select the Power Options icon. Then select "Change plan settings" for which ever power plan the PC is set to use. Then select "Change advanced power settings". Expand the "Processor power managment" by clicking on the "+" symbol. Finally click on the "+" for "Maximum processor state". I would try changing this setting to "90 %". This worked fine on my ACER L100 and it no longer overheats.
    Jun 08, 2008 | AcerPower F1 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    121 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
