Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi Plasma P50S601 no picture sound OK
Hitachi Plasma P50S601 no picture, sound OK, blue power light steady.
Anonymous
Level 3:
  • Master 616 Answers
  • Posted on Aug 30, 2009
Anonymous
Master
Level 3:
Answers
616
Questions
0
Helped
144807
Points
1638
Probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Wont come on at all no blue light
If there is no blue light and no sound, then power is not making it into the unit. Is there a red light when it is plugged in? Many of these plasmas have a primary power switch located underneath or on the back. Make sure that is turned on. If you receive power, there should be an indicator light showing power is present. If it is just dead, as if unplugged, then either the main switch is off or failed, or the power supply may need service.
1helpful
Hitachi tv turns on then gets bad picture than turns off blue light blinking
The name of the part is probably "buffer board" and there are two in your TV - upper buffer and lower buffer, also called SDR-U and SDR-L boards.
Those are the two most common sources of problems in P50S601 along with the Y sustain board (SD board in hitachi and Panasonic terminology), which sometimes gets damaged by the failed buffer board.
In the buffer boards market there are all kinds of offerrings. There are old buffers for around $130 for the pair and there are new buffers in the range $160-$200 for the pair.
In my opinion if the difference is barely $30-$40 one is better off going for the brand new ones.
Here's a link to our title for them, you can sure find others if you start from it:
http://www.coppelltvrepair.com/p/182/hitachi-nd60200-0048-and-nd60200-0049-replacement-set-of-buffer-boards
Hope this helps!
1helpful
2answers
Need a schematic for model p50s601
This web page may help it has links telling you what to test. http://www.hometheatershack.com/forums/hitachi/30302-p50s601-blue-power-light-flashing-3-times.html like if your power light is flashing 3 times then it most likely is two caps in the power supply and one of the sdr boards.
2answers
I got new power supply for my tv and still doing same thing, blue lite stays on only way to turn of is up plug it its a hitachi 50s601 plasma little more then 1 yr old, i talk to a tech and he maybe a...
blue light on is a good indication that the power supply is up not always but not replanding to commands is always the main board the cpu and commands are not talking
2answers
Blue light blinking-
I would say you are lucky to get a pretty fair price, sounds like a convergence problem- if the tv is a projection wide screen. worth the investment Julio [email protected]
2helpful
2answers
No Picture or Sound, Blinking blue light
the bulb is blown, replace bulb prie 150.0 to 250.00 it is not a hard repaitr to do yourself.
1helpful
2answers
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
