Question about HP Compaq Business Notebook NX9010
Startup problem I have a three years old pentium 4 nx9010 that has developed a startup problem. When the machine is turned on (mains power) it very soon begins to emit a rapid and continuos beeping. The only way to stop it is to press the escape key. It will then begin the boot up process. When it asks for a logon password the ctrl alt del message appears and flashes rapidly. Again the escape key stops the flashing and after entering the correct password it appears to open windows xp pro as normal. However the problem does not stop there. When I click on start and go to all programs it has a mind of its own and will open automatically the first program that the cursor passes over. My question: - is this a hardware or software problem, how do I fix it short of buying a new laptop?
  • warrigal Dec 07, 2007
    I have tried ti carry out the first solution without success. The F10 key does not start the BIOS Utility screen, however F2 does. When the BIOS utility screen is open it shows the tabs as Main, System Devices, Security, Boot and Exit. I have searched everywhere within the BISO information and there is nothing that indicates Options, diagnostics or tools or any function that resembles these headings. What can I do?.
  • Anonymous Dec 08, 2007
    even i,am also facing the same problem after formating the pc still it is behaving same like before can anyone comeup witha solution?
I had a beeping problem like this, turns out a key on the keyboard was defective and was continuously depressed, as you could imagine that would cause this seemingly erratic behaviour.
Posted on Jan 30, 2008
    Novelist:
  • 69 Answers
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to startup issues on your Laptop.. I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Well, let me tell you. This issue could happen due to following below possibilities...
1. due to Bad RAM.
2. due to BAD Hard -Disk
3. Due to Operating System ( Windows XP Professional) corruption...
To isolate and to resolve the issue, please try below solution.
firstly, we need to test the Hard-drive Functionality.... below steps will hep you to test the Hard-Drive..
Steps are :
1. Turn off your laptop. wait for 3-4 minutes...
2. try to restart the Laptop, immediately press and hold F10 key.., this will get you into BIOS utility screen...
3. In the screen you can see Main, Security, Advanced... so on options. Now try to locate to option that says " Diagonistics or Tools ". and then select it.. and then select the option " Hard-drive self test( quick test).
Note**, Mouse will not working in BIOS screen, hence use up and down arrow keys to select the options...
The purpose of this solution is to test the Hard-drive functionality,....
Once if you select the Hard-drive self test option, it under goes the test... and reports a message at end of test...
Make a note of message. and let me know... .Each message would have different issues. Hence, make sure that you make a note of error message and let me know the complete message...
Okay???
Anyway, let me tell you few error... if it says like .." 1-07 failed Or 2-07 failed". This confirms that Hardware is bad. And hence replacingg the Hardware will resolve the issue for you...
If you receive any other message that says like test if ok... then it confirms that Hardware is fine. and need to perform the next solution...
Solution 2:
Second possible issue could with RAM. Hence, I recommend you to test the RAM. Please manually remove the RAM cards from Laptop( for this process please refer to user guide for instructions on RESEAT OF RAM).
Once if you remove the RAM cards from Slot of Laptop. then check for damages on cards and also in slot. If you find damage on cards then replace the new RAM cards.
else if you find the damage on slot, laptop needs to be serviced. Then contact service center.
However, at this moment, there are few situations that only ram card will be gone bad. Few Laptops, come with 2 RAM cards. Hence, to isolate this factor try to swap the cards and check the issue by restarting the Laptop.
Else check the issue by put ting only one ram card and restart the laptop.
This should generally isolate the issue.
But******* be careful, that you need to remove the battery and also remove POWER cable that is connected to Laptop before you try this solution...
if every thing is fine, then only possiblity left is Operatingg system.
Then please go ahead and reinstall the operatingg system... this will resolve thee issue.
As per my experience, I guess on Operating system issue... Anyway please try all the solutions that I recommend you.
Let me tell you about me much more. I do work for HP. If you would like to go for a new Laptop. then please let me know... so that I can help you with information on best Laptop for you and also will help you with purchase directly from HP.
If you would like to get it from directly from HP, then please do let me know below information..
First Name :
Last Name :
E-mail address :
Preferable time to call you:
( you will receive a call from HP directly)..
Time Zone:
Telephone number /Alternate number( along with area code).
Please e-mail above information at thumuvikram@rediffmail.com
This should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Dec 06, 2007
  • Vikram Kumar Thumu
    Vikram Kumar Thumu Dec 06, 2007
    I see that you have replied to me..............
    Vikram Kumar Thumu Dec 09, 2007
    hi,
    Few Laptops do not have feature of testing the Hard-Drive self test. I recommend you to try other solutions as suggested. If all others fail, then it confirms that it is an fault with HardDrive or with System Board in laptop.
    Bye.
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Computer will not boot to windows. the screen displays phoenix - awardbios v6.oopg, an energy star ally copyright(c) 1984-2004, phoenix tehcnologies, ltd p4m800-m7 (pm48m309 bf) main processor: intel(r)...
The light you're referring to is the HDD Activity Lamp.
(HarDDrive)
It blinks green when it's operating, and orange for inactivity, or not operating.
You're getting to the BIOS Post screen, but BIOS is handing over the computer to the Operating System.
(Windows XP is an example of an O/S)
When you press the Power On button;
1) A temporary connection is made from the motherboard to the power supply. A 5 volt circuit is made. This turns the power supply on. (Soft Power On)
2) The BIOS chipset, is the first chipset to receive power. (Chipset is a slang term for IC. Integrated Circuit)
The BIOS program, ( 64MB in size), looks to see what all devices are connected.
(Harddrive, optical drives, mouse, keyboard, etc.)
3) Then BIOS does a Ram Memory count,
4) Turns the Processor on,
5) Then hands the computer over to the Operating System.
It looks like BIOS has recognized your Intel Pentium 4 processor, (2.66GHz frequency rate, 533MHz FSB), but hasn't turned the processor on.
[Let me stop,and explain something real quick.
Where you see -
Intel (r) Pentium (r) 4 cpu 2.66ghz (133x20.0)
The r stands for Registered. Intel and Pentium are registered trademarks of Intel Corporation.
It's a Pentium 4 model.
2.66GigaHertz is the Frequency Rate. Slang term for frequency rate is 'Speed'.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
At maximum capacity, your Pentium 4 processor can operate, at a 2.66 Billion Cycles per Second frequency rate.
133 stands for 133Mhz. 133 MegaHertz.
Mega = Approximately 1 Million
This is the Clock Rate. Intel processors are 'Quad-Pumped', so the FSB is actually 533MHz.
(FSB = Front Side Bus)
The 20.0 is the multiplier.
20 times 133Mhz = 2600 Mhz,
or 2.66GHz ]
Now, why is the processor not turning on?
Suspect the Power Supply.
Not enough power to turn the Processor on.
1.ALL the lights for your computer use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical processor uses 55 to 125 Watts!
(The Processor hasn't been turned on, so nothing else is receiving power yet)
This is the basic specifications for your processor,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Scroll down the left column of the list.
Where you see Pentium 4 505, Pentium 4 505J, and Pentium 4 506. Your processor is one of these three.
Scroll across. You will see 2667 MHz. 2667Mhz is rounded off to 2660 MHz, or 2.66GHz.
You will see 533M/T as you scroll across.
M/T stands for MegaTransfers. A more accurate description of FSB. Front Side Bus.
Scroll further across. You will see 20x. This is the Multiplier. (Look up)
Lastly scroll across a little further. You will see 84W.
This stands for 84 Watts.
Your processor operating at maximum load, uses 84 watts.
Why do I suspect the power supply?
Because it's the number 1 thing to fail in a computer.
Electrolytic Capacitors fail inside, or are failing.
They have Electrolytic Paste inside them.
The paste has developed a gas, (Hydrogen gas), and has popped seals for the capacitor's case.
This results in Electrolytic Paste slowly oozing out of the capacitor, and resulting in the capacitor failing, or has failed.
Electrolytic Capacitors are used as Filters in a computer power supply. They filter the incoming AC electricity from your house, and the outgoing DC electricity made from the power supply.
When capacitors are failing, or have failed, they create a bad power rail.
There are three main power rails in a computer power supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
With a weak power rail due to failing capacitors, or a bad power rail due to failed capacitors, you do not have enough power to turn the processor on.
Solution?
Use a known, good, compatible power supply for a test. If the power supply is found to be bad, replace it.
Questions?
Dec 20, 2009 | Biostar P4M80-M7 Motherboard
OUR 40" SAMSUNG LCD TV IS THREE YEARS OLD AND NOW TAKES ABOUT 15 MINUTES TO SWITCH ON EITHER FROM STANDBY OR FROM THE MAINS.
capactors are failing will not turn on at all soon and the light will flash
replace capactors on mains power board easy to do if got soildering iron look for raised tops on capactors ( they look like little battries with line down and numbers on (e.g 20000mf 25v) there is 3-4 that will need changing close together
replace with some value and make sure the line is on same side as ones that you take out TAKE PICTURE FIRST and replace one at once
Dec 15, 2009 | Samsung LE40R74BDX 40 in. LCD Television
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Feb 28, 2009 | Washing Machines
Dell 1600n Display panel freezes soon after power up
it is definately a problem with the startup cycle circut but will need testing to determine the exact cause , it old enough that they may have stopped making parts for it though
Oct 08, 2008 | Dell 1600n All-In-One Laser Printer
Remove floppy drive compaq nx9010
You can try the link below. It should have a breakdown diagram. If I may ask why, I'm a computer tech, and I've only used my floppy drive two times in the last three year, and that was to make a bios flah for a couple of ancient machines. Your laptop is relatively new.
Jun 24, 2008 | HP Compaq Business Notebook NX9010
My 4 month old Samsung Le32R87BDX television has recently developed a problem where it keeps on cycling down through the channels automatically. When this happens the only button on the remote control that...
Since the set is only 4 months old, it should still be under warranty. DO NOT open up the set as that will void the warranty. Call for warranty service and indicate that this is an intermittant problem. If you can report any pattern about when this behavior occurs, that info will be helpful in resolving the problem.
Keep us posted.
Dan
Jun 09, 2008 | Samsung Televison & Video
HP NX9010 automatically shutdown
Definitely a software problem, somewhere along the installation process, the data on the CD is being read wrong. Try a different installation disk, and see if this fixes the problem. If not, then it could be that there is either a problem with the CD drive, or the IDE controller for the Hard Drive.
Feb 25, 2008 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9010 Logo
311 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
