From PC to cellphone
Hi. how can i transfer ringtones from my computer to my cellphone with windows media player?
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP ' eHow.com http://www.ehow.com/how_12186594_download-mp3-mtp.html#ixzz1wFmzrcvt
May 29, 2012 | Nokia C203
How do i download a ringtone on my cricket kyocera cellphone
download first the content using your computer in a specific website of your choice, then using your USB connector (depends on your provider) connect it from your PC to your cellphone and from there the ringtone will be transferred towards your mobile phone
May 15, 2011 | Kyocera Computers & Internet
How do I transfer my music ring tones from my laptop to my Palm Pre cellphone
The ringtones have to be in .mp3 format. If they are in .wav they wont work. First, connect your phone to your computer with the usb charging cord that came with the phone. Secondly, a notification should pop up on your device allowing you to select usb mode or just charge. Select usb mode. Then go to my computer on your computer. you should see a directory that says Palm Pre. enter that. Then open up a new explorer window and find where you put your ringtones. Select them all and right click and click copy. Then go to the first window, and right click, then click paste. remove the phone when its done transferring. When you go to sounds and ringtones settings on your phone, you will see when you are selecting a ringtone a little button in the lower left hand corner. Tap it. this will allow you to add files to your ringtones. After you tap them to add them to your ringtones, do a back swipe. Then tap the ringtone you want to use.
Mar 29, 2011 | Palm Pre Cell Phone
I cant transfer my ringtones from my san disk to my phone
Hi chad0872,
First and foremost, you can't do anything if you don't have all of the components needed to do the job. You will definitely need a computer. More importantly, you will also need a Micro SanDisk and TransFlash to SanDisk adapter. The Micro SanDisk is a very small device, approximately the size of a chip. The disk is placed in your phone to store your phone's items for transfer. The TransFlash to SanDisk adapter is used to access the SanDisk files on your computer. Your SanDisk should be at least 256MB for sufficient storage space.
Once you've established and obtained everything you need, you can now begin the initial transfer process. Insert your Micro SanDisk into the phone where your ringtones are stored. Access the Media Folder or Content Management folder in the phone. Highlight each ringtone file you want to transfer. Open the Options' section available for the ringtones and opt to move your ringtones from the phone's storage to the memory card. Once the transfer process is complete, remove the memory card from the phone
Now that you have moved your ringtones to the Micro SanDisk, place the Micro SanDisk into the TransFlash SanDisk. Insert the TransFlash SanDisk into your computer. This expandable memory slot can usually be found in the from of most laptops and next to the USB slots on the front panel of desktop model computers. Once the insertion is detected, your computer's AutoPlay dialog window will appear or an import options will be given. When the ringtones' window opens, drag and drop the ringtone files from your Micro SanDisk to your computer's desktop screen.Then transfer it to your phone,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 06, 2010 | Samsung SCH-a670
Get ringtones from my computer
In order to do a music transfer from your computer the only way is either with bluetooth if your computer is capable or with a usb port compatible with your phone. You can always go to sites like Myxer.com or Funformobile.com and probably find the songs there for free as well.
Jan 24, 2009 | LG Vu CU920 Cellular Phone
MotoRazr V3m transfering music from minisd card to a ringtone
You may need to have some type of file converter on your computer kind of like windows media player has or I-Tunes. These will convert on command.
Sep 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
I have a zte c79 cellphone that has an mp3. player the phone came without the software disk to install the program that enables me to transfer mp3's and pictures. however it came with the USB cord. but...
when you plug in the usb cord somtimes i'll get a box asking what i want to use windows media player or open a folder with the contense. Then some times i get the add new hardware wizard which doesnot find the program to run the hardware correctly.
so the only way i found to load mp3s onto the ZTE C79 is to get a micro sd car and reader. when i plug i in a box comes up with the same results windows media player or a folder option i click the folder option. and if you have mp3s in your windows media player then right click on a song and open file location it will then tell you wether they are mp3 format or wahat drag and drop the mp3 format songs into the my music folder which is in the removable disk folder . As long as they are mp3 they will play on the phone. as for ringtones the only way i found to load them is to actually record them with the record memo tool in tools. which sucks because they usually end up being all distorted or very low volume. So if anyone know how to load ringtones please let me know
Sep 08, 2008 | Lands Phones
Connect MP3 player to cellphone
Can you be more specific:
Are you trying to play the cellphone through the MP3 player,
or vice versa.
If your goal is simply to transfer jingles and tunes, the best
way to do this is to use a computer. The Motorola phone has
USB and Bluetooth connectivity, see:
http://en.wikipedia.org/wiki/Motorola_RAZR_V3
With the right software, you should be able to transfer
songs and jingles between your PC and the computer.
(Check Motorola for downloads)
The same is true for the MP3 Player.
The only glitch you may find is the compatibility of
the two devices' media file structures.
You may need to download two separate audio file
converters:
Cellphone <==> Windows WAV format
MP3 player <==> Windows WAV format
Finally either (or both) devices may have built-in DRM
(Digital Rights Management) copy protection,
so you may need to download some hacker/ripper
software to recover the original audio.
Google for copy protection by brand name.
Hope this sends you in the right direction.
Martin
Apr 24, 2008 | Motorola Mobility RAZR V3
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Using Windows Media Player 11 or Real Player 10.5 to Transfer Music
make sure to use the applet in the system tray (bottom right corner) that when left clicked, opens a list of available usb devices to stop before disconnecting.
Jun 01, 2007 | Samsung Napster YH-920 MP3 Player
Computers & Internet Logo
Alun Cox
David Payne
David Payne
