1992 Nissan Pulsar N14
Thermo fans don't come on, Temperature gauge needle will move up to white line at turn of ignition but will give no further reading, plus where do I find the thermostat on this motor? please help,
Thanks.
Don
    Scholar:
  • 93 Answers
Thermostat is usually at the motor end of the top radiator hose.. under a cap usually held down with 3 bolts (working off memory, its been a while) sounds like you have a short somewhere, look around engine bay for black, burnt, or broken wiring; failing that take dash apart and the gauges out and check the wiring behind there.. and fuses (obviously)
Posted on Dec 07, 2007
What much oil to put in gearbox on Nissan Pulsar N14 1992, manual. And how to check level?
the oil filler plug in the side of the box is the fill level
add oil through the hole until it runs back out and that is the fill level
( level with the threads in the hole )
Nov 08, 2015 | Nissan Cars & Trucks
Immobiliser does not work - engine immoblised. Rest of electrics operate normally.
WHEN U SAY WNT START DO U MEAN CRANK OR JUST TURNS OVER WITHOUT RUNNING.. IF IT TURNS OVER AND DOES NOT START IM ASSUMING U CHECKED FUEL PRESSURE. IF SO CHECK UNDER DASH memory fuse. also check ignition fuse
Mar 24, 2014 | 1990 Nissan Pulsar
Hi have a 92 nissan pulsar n14 gli and the odomiter works and then stops everything else in the das works spedo temp fuel, any ideas it's not the cogs, and where is the relay for these ? checked all...
a comon problem with nissans is speedo &rev counter pointer needles warp and get stuck on the instrument face.if this is happening with yours u need 2 remove the clear plastic face heat the needle with a hair dryer and very gently bend the needle tip out from the speedo face hold it out till needle cools ps.dont over do the heat it wont need much
Sep 11, 2011 | 1990 Nissan Pulsar
I've got a 91 Sentra N14 Hatch, drivers door wing mirror has been smashed off, (man adjustable) what models would the same mirror come off Please?
Most vehicles have their own unique mirror assemblies and are not interchangeable.
I'm certain the N14 is the same in this case, so you would need to find any Nissan vehicle which has the N14 chassis code (e.g. Sentra, Pulsar), as the mirror mounting bolt positions will be specific also.
The N14 mirrors also come in both manual lever as well as electric.
Cheers,
Sep 05, 2011 | 1990 Nissan Pulsar
Nissan pulsar 1992 N14
no its usually always located right off the radiator hose to regulate the heat and pressure. there is a good chance the part store gave you the wrong one
Feb 22, 2010 | 1990 Nissan Pulsar
Fuel Guage Problem on Nissan Pulsar N14
Either the sending unit in the tank is bad, or the gauge is bad.
Mar 09, 2009 | Nissan Pulsar Cars & Trucks
Temperature and gas gauge not move
I would start by checking connections behind cluster and check all fuses
Jun 07, 2008 | 1992 Nissan King Cab
Computers & Internet Logo
245 people viewed this question
Alun Cox
David Payne
David Payne
