Question about Samsung (SP0411N) 40 GB Hard Drive
S.M.A.R.T Command failed
Hi
When my sys is about to start booting it is displaying
primary master harddisk S.M.A.R.T Command failed , press F4 to resume
I am using Intel motherboard. what does it say, is my harddisk about to die.
  • 6 more comments
  • Maki2000 Feb 23, 2008
    Its the same problem as mentioned with the S.M.A.R.T. notification of "command failed".I tried reformatting and re installing my OS thinking that it was an OS problem,I even tried replugging and reconnecting my hard disk again,but the same problem during start up occurs.There was even a time,that after reformatting,all windows application/program would crash down,and eventually the pc itself would stop responding to any commands given.
  • Anonymous Mar 04, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to chait's S.M.A.R.T Command failed problem, and notify you when a new solution is offered.
  • svprasad Mar 31, 2008
    i had the same problem secondary master harddisk S.M.A.R.T Command failed , press F4 to resume
    I am using Intel 845 gvsr motherboard
    after pressing f4 things goes as usual
  • Anonymous May 12, 2008
    after displaying 2 messages that S.M.A.R.T. failed my hard disk is not detected by bios. and prompt me to reboot but it not works
  • anirban SURAI May 15, 2008
  • zaggy8088 May 26, 2008
    I have the same problem with my intel perl mother board, The hard drive causing the problem is less than a year old, WD 500g and its a slave,The
    master is 100g seagate and its 5 years. I remove WD 500g and the problem goes away.
  • sirbalaji Jun 15, 2008
    Pri master hard disk :SMART command failure press F4 for resume
  • Anonymous Jan 05, 2009
    hgfgh
  • 36 Answers
It means that the hard disk SMART monitoring system has detected problems serious enough to warn you of the growing possibility of hard disk failure. Sometimes a drive will last quite awhile after this first notification, but there is a good chance of imminent failure, in minutes, hours, days, or weeks. You should immediately look into installing a replacement drive.
You should immediately copy any important data off the drive, perform full backups, and limit use of it.
If you can install drives yourself, a new hard disk (especially Seagates) usually come with software to clone your existing drive to the new drive. Otherwise, a repair shop will be able to do it for you.
I recommend also purchasing a drive enclosure for your old drive. For whatever life it still has, it will be a good backup of your system.
Posted on Dec 06, 2007
Format with fat32
Posted on Sep 22, 2008
How do I back up my computer when this message appears Pri Master Hard Disk : S.m.a.r.t. command failed Press F2 to resume
restart computer and press delete button and in BIOS menu go to advanced menu set S.M.A.R.T disabled.
Jun 10, 2012 | Sony VAIO PCV-RZ44G PC Desktop
What will i do!after i shutdown my compaq Evo N800v laptop,and remove the harddisk for me to copy some larger files on my another laptop!and when i put the harddisk back and power it on,it just hang up on...
It looks like one of the start up files have been changed or corrupt. Any change to the boot environment will cause this problem. The solution here could be a bit long but you just have to take your hard drive to the other computer and back up all your user data and files you need. Then take is back to the Laptop, just in case anything goes bad. Get a copy of the operating system you are using on a CD and let the computer boot from it by pressing F2 or Del to get into the BIOS and go to the Boot Sequence or Boot order to make the CD rom the first device to boot from. Then press F10 to save and exit. This will allow the computer to boot form the CD. Choose the repair option to repair the master boot record. If you are using Windows XP, put the CD in and choose Repair on the first window. This is a command prompt and this is what you are going to type in the command prompt to install the Automatic System Recovery (ASR) winnt32.exe /cmdcons and this will install the recovery console. In the recovery console, type fixmbr to fix the master boot record
Feb 22, 2012 | Compaq Evo N800V PC Notebook
Hi, I am using a toshiba satellite L645 which i got last December. I am now receiving the following error on boot... "Intel UNDI, PXE - 2.0 (build 083) Copyright (C) 1997-2000 Intel...
it seems that your harddisk is not dettect or may be your os has failed to boot.
turn on your laptop and press f2 to enter system setting
check on main field your hdd (ide configuration) is there any hdd installed? if there is no hdd instaled, it means that you need to replace your harddisk with a new one.
if there is any hdd now check your boot setting (boot priority), set your first boot in cd room and the second in hdd (in order to make easier instalation if the windows has broken) then save and exit.
May 13, 2011 | Toshiba Satellite C650DST2N02 Laptop
When I was trying to boot the system the following error is getting flashed on my screen and asking me to press F4 to continue. pri master hard disk: S.M.A.R.T. command failed
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 01, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
We got the problem in our internal segate harddisk. when the system is on, shows the error message of Boot disk failure.
This sounds like a problem with the hard drive's MBR (Master Boot Record) If you have a windows xp disk, insert it and boot from it, make sure that your cd-rom device is set as the first in the list on your boot priority in your bios. Here are the steps for xp and vista
So how can you repair your damaged MBR? Here are the steps to follow:
1. First, restart your computer with the Windows XP setup disk in the CD drive. If you don’t have your original disk, borrow one or download a ISO image from a torrent site.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Note that you may also want to run the fixboot command to repair the boot sector with a new one.
Also, make sure you only use these commands on a system with one operating system installed. If you have more than one operating system installed, fixmbr and fixboot could mess up everything.
Fix MBR in Vista In Vista, the procedure to fix the master boot record is a bit different. You have to start up Vista in the Recovery Environment and then run the bootrec command. Here’s how.
1. First, load up the Windows Vista disc in your drive and press any key to boot from the disc.
2. Choose the language, time, currency, etc and click Next. Now click on Repair Your Computer.
3. Choose the operating system to repair and click Next. When the System Recovery Options dialog comes up, choose the Command Prompt.
4. Now type bootrec.exe and press Enter. This will rebuild the boot configuration data and hopefully fix your problem. You can also run the command with switches to fix just the master boot record (/fixmbr), the boot sector (/fixboot), or rebuild the entire BCD (/rebuildbcd).
If you are still having trouble with loading Windows, post a comment and I’ll see if I can help! Enjoy
May 25, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Computer freezes when I start it
Please make sure the boot device is correct from BIOS.
If correct please boot your system from Windows XP bootable CD and choose recovery option in Command Mode.
run the command
chkdsk /f C:
Check the result and let me know if any error comes.
Jul 30, 2009 | Computers & Internet
"primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
American Megatrends is telling us our Pri Master Hard disk: S.M.A.R.T. is bad, backup and replace.
By questions and answers from above, is this telling us to replace hard drive?
Aug 14, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
6,015 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
