GE 30 in. Profile JP350 Electric Cooktop
Problem for GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
By joywillrett on Aug 30, 2009
I have a four burner GE electic cooktop with a large front burner that can be changed from a large burner to a small burner. Unfortunately, no matter where I put the knob, it cooks on high. Do I need to call a repairman?
Best Solution
posted on Aug 31, 2009
Very Helpful)
Controlfrk
Rank: Guru  GE Expert
Rating: 94%, 90 votes
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE 30 in. Profile JP350
Questions and Unsolved Problems for GE 30 in. Profile JP350
Do you recommend GE 30 in. Profile JP350 Electric Cooktop?
Answer
Answer
Purchased a used smooth cooktop, GE profile. Hubby was going to test it, before we installed. It... (More)
Answer
I was boiling a small amount of water and inadvertently let the water boil out and it stayed on the... (More)
Answer
need to purchase white knobs for GE jp 350 cooktop
Answer
There's no control with the duel element on the front right side of the cook top. Does the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 30 in. Profile JP350...:
Top Kitchen Cooktop Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Cooktop Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
