Question about Tally T2250 Matrix Printer
Tally t2250problom page setup problom
Go in setup ,check paper ,inside size ,width,
select one that u want and save it & test
Posted on Dec 07, 2007
    Scholar:
  • 132 Answers
You can use the TOF function for setting the position of the first printing line for each paper
source and each menu individually.
Before using the TOF function (if fanfold paper is used), you should first set the tear position (see
above).
Press the Setup key. The printer changes to setup mode.
Press the Adjust (2) key.
Press the TOF (3) key.
The paper is fed to the position where the bottom edge of the first printing line is aligned with the tear edge. The factory setting for the first printing position (TOF) is 12/72".
Press the < (2) or > (3) key to move the first printing line to the desired position.
You can set values in the range from 0 to 220/72" for fanfold paper and for single sheets.
Confirm the setting by pressing the Set (1) key.
Press the Setup key. The printer is reset to the initial status.
The setting made will be retained after switching off
the printer.
Here is the user manual:
ftp://ftp.tallygenicom.com/pub/genicom/docs/tally/serial/t2150/063112a_OM2150_gb.pdf
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Iam having probloms geting my microphone to work and having a problom hooking up my speakers
this model needs to be hooked up to an amplifier for speakers to work..it has no audio amplifier inside...as for the mic's..you'll need to make sure you have the mic inputs that you are using selected in the setup menu..there are the xlr{3 pin} connectors and the 1/4" connectors..check the setup
Jan 08, 2011 | Tascam 2488 Portastudio Multitrack...
I have a tally 2250 dmp. The setup is blocked. How to unblock the setup options
simple, power on the printer with pressing onine button, then it will unlock the setup button.
Aug 10, 2010 | Tally T2250 Matrix Printer
How to connect tally with excel file? sir/madam i want to connect my tally erp 9 with my stock (excel file) i maintain the inventory in tally, when i make a bill on tally on that time it automatically...
hi
deepu
in tally 9 ERP has a oprtion to export any date from tally to excel just open that page which u want to open in excel
then see on the top in tally page there is option for export file just folwothat u will able to export dot in to excel
Jun 26, 2010 | Peachtree Software Peachtree Complete...
Tally Printer setup
tally packager how to change print area in page set up
Jun 01, 2009 | Tally Matrix T2280 Printer
In Tally T2240/24 Matrix Printer i am not able to take test page,
The menu on the T2240 is locked to prevent accidental changes to menu settings, you can unlock the menu in the following way;
  1. Start with the printer powered OFF
  2. Hold down the SETUP button
  3. Keep the SETUP button held down and power the printer ON
  4. Keep the SETUP button held down until the printer has finished initializing, then release the SETUP button
The menu will be unlocked until the printer is reset or powered off.
You can turn the menu lock off by changing the MENLOCK option in the printers menu to OFF.
Mar 31, 2009 | Tally T2240/24 Matrix Printer
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Jan 02, 2008 | Tally T2245 Matrix Printer
Tally T2250 Matrix Printer Logo
404 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
