Question about Toshiba 62HMX84 62" Rear Projection HDTV
Not the lamp!
I having a problem with my tv not turning on. I have a toshiba 62hmx84 cinema series, not even three years old! I replaced the lamp five months ago and everything was working fine until a few weeks ago. I thought it was the lamp again because I was getting the same blinking lights and was having the same indications like I did the first time. So I replaced the lamp and still got no picture. Is there a next step I can go to or part to replace before I call a service guy? Sometime it turns on and sometimes it doesn't. Any suggestions would be helpful........Thanks.
  • jack moramarco Dec 07, 2007
    Is it very difficult to change the ballast on a Toshiba 62hmx84?
    Problem Solver:
  • 11 Answers
I would concure with tvtek on this one. See if you can see a kind of spark or ignition flash on your ballast module. It looks like sort of fuse the diamiter of a pencil and maybe 1/2 inch in length.
Posted on Dec 07, 2007
    President:
  • 1,284 Answers
The ballast is available by its own and the part number is 23122468. There also could be a defective saftey swich or possibly a fan has stopped working or not giving the possible feedback that it is rotating. I would have a technician look at it but at least you know the ballast is availble on its own.
  • 87 Answers
If the lamp did not cure your problem you have a defective optical block. This includes the ballust for the lamp. On Toshiba sets the the ballust comes with the optical block and connot be purchased seperately. Prices vary acroos the country and from shp to shop but you are likely going to spend about $800 to repair this.
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Just replaced the lamp on my Toshiba 62HMX84. Picture still is not coming on I have sound. When you turn on the TV you hear a clicking sound that goes away and then the TV try's to restart itself Thinking...
I have a 62HM84 Toshiba TV. I lost picture on my TV in the past i have bought the lamps and i just put it on and the picture comes on. This time when i replaced the lamp nothing happens no picture. It tries 8 times to turn on, but nothing happens. Can you help me with is what is the problem.
Dec 15, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
62HM15
Same problem with mine...
Jun 04, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
I have a Toshiba DLP 62CM9UA
hello everyone, I have been in this field for many years and if you have any problems about projector lamps or your projector ,pls just inform me and i will try my best to solve these problems. I am now still engaged in original projector lamp modules/ original bare lamp/ original lamp with housing/ replacement lamp/compatible bare lamp/main board/liquuid crystal chips/color wheel and other related accessories for the most popular projector brands... if u want to buy projector lamp ,welcome to contact with me. tks&best regards Grace MSN:myth_grace@hotmail.com skype:myth_grace email:grace@awolamps.com
Dec 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Bad lamp?
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
310 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
