Question about Vacuums
How to open the hoover DM4526 to change the belt
My Hoover vacuum DM4526 has a broken belt and I can't open it u enough to get the new belt on. Any ideas?
Many thanks
Penni
  • oldtearly Dec 06, 2007
    Thanks I appreiate your help, but I dont have 5 screws! I had two which allowed me to take the top cover off the base of the hoover, which I had already done, and then no screws in sight.
    However, I exmined it yet again after reading your reply, and found some 'give' in the roller, so I could just ease out one end to put the band round. Not so easy getting it back, and no way of putting it all back together as it was before. However, it may look a complete mess, but it is working!!
    Thnks
  • Anonymous Mar 20, 2014
    change broken belt
    Problem Solver:
  • 9 Answers
There are normaly5screws 3in the front 2in the back remove these and the bottom should come off pull the brudh off repace belt on to brush put brush back in to seating pull brush on to drive and re,asemble
Posted on Dec 06, 2007
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 04, 2010 | Hoover S3606 Bagged Canister Vacuum
Does not vacum
You may have a broken or stretched belt. The machine could also be clogged. Here is a link that will take you to a site that will show you how to open up your vacuum to look for clogs and to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 29, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
U4771-900 doesn't work... How do I open it up to see if the belt is broken?
I'm not familiar with this model number that you have given. Is your vacuum a Hoover model? If so you can get any Hoover belt here:
Replacement Hoover Belts
Nov 06, 2009 | Vacuums
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
LOUD noise
The armiter or fan is broken and if you get it replased it should work like new
Jul 24, 2008 | Hoover U5227-930 Elite Upright Vacuum
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
235 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
