Question about Kenwood VR-7080 Receiver
Full Surround Sound
I hav a kenwood V6100D. I have attached a digital optical cable from my dvd player to the receiver but for some reason im still not gettig dolby digital ex or dts and only the L & R speaker lights are showing, can u please explain why and how to fix?, appreciate it.
    Problem Solver:
  • 14 Answers
Dear Jennis,
Have you set properly your input source? What about program mode on your playback on your amp was it properly set. You have to let the amp knows that you are using an optical cable for input, this must be done from the controls.
Sidlahora
Posted on Dec 06, 2007
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Does it support surround sound
Well not buit in, but it has a 92 KHz/16bit Audio DAC/96KHz/24bit decoder and coaxial digital audio output. So to get surround sound you need to connect the DVD player to your home theater receiver using the Digital coaxial/optical output connector (i.e. fiber Optic). Your home theater has to be equipped with the same type of input and you could enjoy your DVDs in surround sound soon.
Note: the optical inputs and outputs are generally capped when not in use and you will need to remove the the cap to be able to plugin your cable.
Good luck and please don't forget your thumbs-up to help me help you further. ty !
Apr 07, 2011 | Sony DVP-SR200P DVD Player
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I want to set up my surround sound i need to know what the cable looks like for digital in and video in looks like is it a fiber optic
That is called a TOSLink cable, it is indeed fiber optic. It is for digital audio only, video is carried by HDMI (which also carries digital audio), component video cables, S-video cable, coaxial cable, or RCA jacks.
For your surround sound from a DVD player, connect your digital audio from the DVD to the receiver's input, then the video out from the DVD to the receiver's input. Now the video out from the receiver goes to the TV and the surround sound should now be coming through your speakers. Post again in this thread if you need more help or explanation.
Jan 05, 2009 | Sony STR-DE475 Receiver
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
No sound out of surround back speakers
It sounds like you don't have your surround sound source set up properly (your DVD player is not set up for PCM sound).
the best quality audio will be to set up either digital or optical audio between the DVD and the receiver.
Once you have connected the optical or digital audio cable between the DVD and receiver, you have to go into the DVD player audio setup and change it to PCM digital audio or you will not get surround sound. DVD players are not set up by default to output surround sound.
Sep 05, 2008 | Yamaha RX-Z9 Receiver
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
Kenwood VR-7080 Receiver Logo
98 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
