Question about Sony KV-32S45 32" TV
Blinking screen then...
So I looked around on the web here and saw a solution to a problem similar to mine. This is where the screen blinks on and off and can be corrected by turning up the screen screw just until the pic came on. And that was great. Bam, the picture came back on! I put the back on it, then put it back in the stand. I'd say 15-20 minutes later I looked and it had blanked out again. I turned it off took it out, and took the back off again. Iturned on the tv, waited for it to warm up. It popped on and I adjusted the screw all the way right making strange lines and curves. Iturned it back to where the picture was normal. I left it open this time. The picture would still black out,and in order to get it back you had to turn it off and on again. Now it works a little better by bringing the picture back on itself. But, what it has now is the color becomes brilliant and then back to not so. Then it will blank out and come back on by itself. Please help my family can not afford another TV anytime in the near future.
  • bullv3 Dec 26, 2007
    when i turn on set it stays in stand by mode for a minute.then picture comes on and blinks on and off for about 3 minutes then stays on but color not right .
    Genius:
  • 1,694 Answers
Sorry, your CRT is bad.......rejuvenation might help,
replacement of tube not practical.....best solution..replace set...
Posted on Dec 06, 2007
Right blinker double time,side bulb out, Back right blinker burns but doesn't blink..replaced both front bulbs, still blinking double on front and not at all on back...suggestions?
Hey, just a thought, but a friend of mine had similar prob. She drives a ram pickup, and the front turn signals have two turn signal bulbs and they are front bulbs not side. Go out and look at the side that works and then look again at the other side.
Apr 02, 2016 | 2010 Chevrolet Chevrolet Impala LS
Zmodo blinking hdd light
A blinking HDD light means it is reading/writing; under normal conditions anyway. Just means that it's being accessed, that's all.
Now if your TV screen is also BLANK, then you have the same problem I do... I'm just waiting on a reply. Mine is the Zmodo ZMD-DX-SBN8 but should be similar enough, I think.
Jan 18, 2012 | OEM Systems Zmodo Surveillance...
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
My Panasonic PT-53TW53 53 in. was working fine last night when I turned it off. Today it doesn't turn-on at all. it's plugged into a surge protector and no thunder storms today... what could be the...
I am someone who knows these sets very well.
One of two things should be seen:
If when you turn set on it does not come on----DOES THE POWER LIGHT BLINK IN A SEQUENCE?
Most common in this model are 3 blinks, pause 3 blinks forever.
Next is 5 blinks 5 blinks etc forever.
Does your power light blink/
Also, I know this model but what year/month was it made? Date will be on a label on the back.
I helped someone else today here with a similar problem.
In his case the set came on and after a few minutes he saw a faint top to bottom band of noise to the right of center in the screen, the rest was black.
The more you tell me, the better I can direct you.
Regards, SD TECH
Aug 14, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Dell Blinking Power Light
Hi There,
I have worked on several of the Dell 17" and that is almost always the Capacitor problem.
The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
If you can get inside the frame of the monitor, and disassemble, you can find the caps by seeing a bulge on top, or even a rusty looking material on the top. Be VERY careful around the high voltage section if you do go inside.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 04, 2009 | Dell E153FPf 15" TFT LCD Flat Panel...
Tried turning on my Sony and no picture no sound, just a black screen
This is a fault that cannot be repaired by a user. It isn't even a feasible repair , just get a new box
Dec 24, 2008 | Sony KP-51WS520 51" Rear Projection...
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Feb 27, 2008 | Toshiba TP50F50/51 50" Rear Projection...
Sony KV-32S45 32" TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
