Question about Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher
ZDT5052 flashes quickwash light
Hi, My Zanussi ZDT5052 stops after draining water and last program(50-degree quick wash) light starts to flash quickly. It happens sometimes with first water drain, sometimes after last drain. Some cycles are washed normally, but then again, for an example after draining water with washing powder it stops and starts flashing this light. Filters are checked. Same with hoses. No lime. What it could be? Manual doesn't say anything about last light flashing.
Thank You!
  • kostasGR Apr 09, 2008
    I now have the same problem. Things started after having twice the electricity cirquit breaker going off during washing cycles. I figured out that there was no water in, so the heating resistors were heated and caused the cirquit braker to disengage power. Then I changed the water hose and cleaned the filters, so water input was OK but I have the quickwash flashing problem and my wife is complaining dishes are not cleaned well. For the moment she repeats twice the washing cycle.
I had the same problem. After cleaning hose between unit which measures water level (located below, near right leg) and sink everithing works fine.
Posted on Dec 26, 2008
  • 833 Answers
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Sep 08, 2014 | Zanussi Washing Machines
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Apr 05, 2011 | Washing Machines
Some 1 gave my daughter a slimline zanussi dishwasher not sure what model it is but looks quite old. need a manual as the program numbers have faded and cant see them regards chris oh and its a aqua save...
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
Hope this helps.
May 27, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Open Questions:
See all Zanussi 18 in. ZDT5052 Slim-Line Built-in Questions
Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher Logo
652 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
