Question about Dell E173FP 17" LCD Monitor
C5707 transistor whew its so hard to find this transistor. its only available for shipping. does anyone know any replacement for this transistor? tnx and god bless
  • Anonymous May 24, 2008
    LA SE
    LA PANTALLA SE PONE OSCURA
There is a compatible transistor sold at Radio Shack (TIP3055NPN). Here is link to a page that this guy shows how to fix it, step by step.
http://www.josepino.com/other_projects/index.php?howto-repair-dell.jpc
Good Luck!!!
Posted on Jul 22, 2008
    Problem Solver:
  • 10 Answers
There is a guy on ebay that sell these, that is your best solution
Posted on Apr 13, 2008
Hi there im exspertlectronik and telekomunikacione my name is nebojsa for friendcall me BO in last time i fix laptop tft monitor main board and iff i have time and hdd controler,Im in pension so if u want my hellp call me on e mail.nebojsakacarevic@hotmail.com
Posted on Mar 27, 2008
  • nikola tesla Apr 17, 2008
    i nsome case so many transistor can chnage with others and some mosfet also with simply bipolar transistor soun fany but that is true,in IBM tft monitor transistor in dc dc convertor for back light tft display u can change ths driver transistor with BF459 that is driver transistor for RGB in module tv,gate is same like base,colector is dc power and bicouse that tr.working on high frekvencie that is same like to work in impulse regim like FET tr. U al can try with this i fix my monitor and he working more then 3 years.Take care all my friend and bye bye
    P.S my E-maill is nebojsakacarevic@hotmail.com if u need some help u can get me there byeeeeeeeeeeeeeeeee
  • 106 Answers
Under TNX so many transistors are there which one You are talking 'bout?
Posted on Dec 07, 2007
My monitor was just blinking folowing the thunderstom some days back and I tried to replace some 4 capacitors coded C5707,and it comes on but abnormal display and then the replaced transistors burn out...
At this point you may be better off to replace the whole board, the four C5707 are transistors, not capacitor. You need to make sure that there are no cold solder joints around inverter transformers lead, check the tuning caps in the inverter output sections.
Replacement board: http://www.lcdrepair.us
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 12, 2010 | Dell E173FP 17" LCD Monitor
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Benq t7q3
look at the 3 amp. fuse on the mainboard! By the way, you can buy very cheap USB light, wich are working with a small lighttube. Use the transistors of their generator!
Mar 09, 2009 | BenQ T705 17" LCD Monitor
Benq lcd c5707 transistor issues
You need transistors with hfe greater than 300. They are harder to get and you should use the producter`s original transistors 2sa5707.
Oct 18, 2008 | BenQ FP71G 17" LCD Monitor
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Oct 27, 2007 | Dell E153FP 15" LCD Monitor
BenQ FP71G+
We recently come across this problem - and like many others - looked online for a solution without much luck. So it was a clear case of fault finding. The symptoms of the indicator changing from amber to green on signal indicated a problem with the powersupply/inverter board, and not the smaller signals processing board, so that's where we started. On careful testing it soon became clear that the black picofuse (just above the main transformer) was blown. This indicated a major fault in the backlight driver circuit. There are two independant yet identical circuits that drive the backlights - this made testing easy. We found that the two driver transistors marked C5707 were almost completely shorted. You will identify these as being two of four identical black components with a built in heat sink at each end of a grey 0.22 Microfarad capacitor - looking much like bookends! Replacing these C5707 transistors with BD139 transistors (Note: these are constructed mirror image to the original transistors - fit them backwards to the original transistors !) and replacing the 3 Amp picofuse with a 1 ohm 1 watt resistor completely solved the problem ! - Colin Knight, Radtvid Electronics, South Africa.
May 05, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP731 Screen briefly displays then turns off
hi. i had the same problem and fixed it. the problem are the 4 transistors (C5707) one of more are shorted (Q739,Q740 and Q759, Q760). Also the fuse PF751 (3a) has to be replaced in most cases. In my case i replaced the fuse and 1 transistor (C5707)
Dec 06, 2006 | BenQ FP731 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
4,530 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
