Dell P1500 Laser Printer: USB Port is Broken--plastic center peg broken off
Greetings Wise Ones,
My Dell P1500 USB port is broken. Something hit the plug and snapped the little plastic peg in the center of the port.
How can I fix this by popping out the broken port and replacing it with a new one? Or, does it need to go to a repair shop? (I don't solder! And, I destroyed every model I tried to build as a kid with my spatial perception "challenges" and lack of digital dexterity, so if this is more complex than loosing/tightening screw, I am out of my league.)
  • 1 more comment
  • Anonymous Aug 07, 2008
    My wireless mouse was plugged into the usb port and my cats hit the back of my laptop cracking the plastic piece. The piece can no longer be used. What can I do? I dont know if there still is a piece stuck in there. Please advise if I need to buy a new port or if it is easier than I think.
  • hassanmunir8 Nov 09, 2008
    i have the same thing the center peg is broken on my dell printer and its one of the office big old ones i have no idea what to do i have no warrenty on it. there was another port the old big wire lookd like a scart lead but i do not have the same port on my desktop heeellllllllp.
  • ramy-ahmed Nov 29, 2009
    I had the same Problem in my HP deskJet 5150 <
    plz , HELP
    Top Expert:
  • Office Equip... Master
  • 27,861 Answers
If you mean the centre pin from the plug has broken off in the socket then use a tooth pick, dab a tiny bit of cyanoacrylate, (super glue) on one tip and push against the broken pin keeping steady for at least 20 seconds. Now, gently pull the pin out.
If the socket is broken, new board or repair shop.
Posted on May 19, 2017
  • 324 Answers
SOURCE: USB port broken on old IBM Thinkpads
Marite,
Thanks for providing the pictures. You don't know how much that kind of input helps!
In looking at the pictures you've sent, the only way to repair this is to replace the connector. It can be fixed, however you need to be aware that the cost to obtain a part as old as this plus the labor involved will probably be much more than the unit is worth.
One thing that you might want to try is to buy a USB hub and plug it into the working port. A USB hub is a kind of extention cord that will give you several USB ports.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Posted on Nov 20, 2007
mtspace
  • 103 Answers
SOURCE: Printer Not Responding
check the device manager for any errors
delete the printer from the device manager and reboot your pc with the printer plugged in
Posted on Jan 01, 2008
Nitrotrike
  • 589 Answers
SOURCE: windows xp with not recongise HP Laserjet 6p when plugged into a usb port
To my knowledge, the 6P isn't a USB printer, it's parallel port only. Are you using a USB / parallel port adapter? If so, I believe that's the root of your problems - the adapter.
Try hooking it directly to the parallel port (shut the PC and printer down before doing so).
Upon restart, Windows will detect it, and may or may not "know" the model, so you may have to choose it from the dropdown boxes.
If it works when directly connected, you will need to either locate drivers for the adapter (if any), or manually configure it under the printer port properties.
If you need more help, let me know. These are great little printers - once you get them to work!
Posted on Jan 08, 2008
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
Pyrhyc
  • 2028 Answers
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
Where can I get a replacement for my 2 front usb ports on my optiplex 760..they are not working??
I've never seen 2 front USB ports that were bad. I've seen 1 that was defective because the USB device that was plugged into it was broken off. However in that case it caused the power supply to short out and prevent the computer from powering on. Here is a link to your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-760_Service%20Manual_en-us.pdf
If the USB ports on the back of your computer work then the front ones should too unless there is a connector dislodged to motherboard. All USB ports use the same circuit.
Jan 29, 2013 | Dell OptiPlex 760 MT Desktop Computer
How to fix a broken earthernet port hole snap that click and snap the earther net cable in the socket
you can do several things.
  1. have the whole cable replaced
  2. remove the end of both connection and re-crimp the broken end, a computer shop can do it for you.
  3. if you are not in such a hurry, re plug the end again and tape it with the vga cable to hold it in place.
Sep 08, 2012 | Dell Latitude 110L Notebook
I have a dell P1500 and every time I try to print is said offline but the printer say ready what can i do?
assure that your printer is plugged into your computer either by lpt port, usb port, or through the network...
then right click on the printer icon and select use printer online.
Hope this helps!
Feb 23, 2011 | Dell P1500 Laser Printer
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Jan 04, 2011 | Dell U0636 Mouse
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
The G tab came off of my Dell Studio 17.
on the bottom of the key there is little holders and what happens is when you push the key button onto the tactile that goes underneath it, it will snap into place, problem is if any of the little holders underneath the key button or any part of the tactile that it snaps onto is broken then it won't go on properly.
I think that is whats going on here, if your hearing it snap into place but it won't stay on then there is something broken between the tactile or the keyboard button. Your best bet is to get another keyboard probably if you can't get that button to stay on.
Jul 06, 2009 | Dell 0Y3740 Keyboard
Dell P1500 Printer does not print Mriscroft Calendar gridlines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Dell P1500 Laser Printer
Broken usb port, Acer desktop
May be hard to find.
If you have a spare PCI slot in your motherboard, I'd buy a cheap USB card and install it.
Here's some cheap ones online:
http://www.monoprice.com/products/subdepartment.asp?c_id=103&cp_id=10304
You may also be able to get one on eBay reasonable.
Nov 08, 2008 | Computers & Internet
Lost USB power on a DELL INSPIEON 8600 laptop.
unfortunately, the usb hardware is built into the mother board on those...is it under warranty
Oct 13, 2008 | Computers & Internet
Jan 01, 2008 | Dell P1500 Laser Printer
4,951 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
