Question about Mitsubishi WS-65807 65" Rear Projection Television
Mitsubishi TV WS 65869 blinking Green Light
I unpluged my tv power cord over night and it wont turn on anymore when i plug it in now. The green light that says timer on top just keeps blinking the whole time. I have unplugged the tv for several hours and hit the reset button as well. No luck. Please help.
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
This is a common problem with Mitsubishi rear-projection TV's.
See my post at http://www.highdefforum.com/showthread.php?t=58189
or email me at pds318@verizon.net. I can send you the instructions I used to successfully repair my Mitsubishi WS-55613 which was doing the same thing....
Posted on Dec 08, 2007
On the inside of the tv, there is a circuit board with a metal cover over it. looking in from the rear, it is the tallest one and to your left. its where your usb ports are and also the digital audio ports.its tricky to get it out but once u do there will probably 4 capicators on one corner that will be swolen. they are bad if u see this. you will need 4 16volt 1000 uF(micro Farret) 105degrees c. once u have soldered them into place and are ready to install make sure u get the board in line tn the groves of the plastic line up tool that will still be attatched on the board, and make sure u get the panel conected. plug your tv in wait bout a min, the light dosnt go off reset and wait one more min. it this dosnt cure your problem you probably have a bad module. but if it does work you have a cheep fix. the capacitors are only about 25cents each on mouser.com, and anyone can buy from them.
Posted on Dec 09, 2008
I have mitsubishi 65" platinum series plus tv model WS-65869. the power green light continues to blink for three days know, and will not reset.
I am assuming the television is not powering up and the only thing it is doing is showing the blinking green light.
Unplug TV from the wall and see if it will reset itself.
If unplugging doesn't fix the problem then you need to find out what is causing problem. First thing to check are the fuses. Second thing to check is looking for burnt resistors or bulging on top of capacitors. Something caused the TV to enter so called safe-mode.
TV's carry alot of voltage in them so BE CAREFUL and UNPLUG THE TV.
If you are handy with a soldering iron then you can save yourself alot of money. An average service call & repair is $300-$450.
Oct 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
1,338 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
