Question about Nikon D40x Digital Camera
Springing sound There is a Spring Ringing sound when i shake my slr... will that cause any problem in future????
  • 108 Answers
There want be any sound like that in D40X try without lens after that also if you get the same wired sound take it back to service center.
Posted on Dec 06, 2007
I just asked about my washer vibration and did you answer my comp. kicked out and I did not get my answer
Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 11, 2015 | Washing Machines
Drum wobbles when empty
Apr 02, 2015 | Whirlpool Wfc7500vw Washer
Tub is crooked, could a balancing spring come loose
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Feb 12, 2014 | Estate Washing Machines
Sounds like metal tapping and really rough shakes when car is running. It died on me then cranked it up and it starting shaking and heard metal tapping. sounds like a baseball card in bicycle spoke
You may have a valve spring broken,or the timing has jumped,do not try and start it again,have the timing belt checked first cause it can bend a valve,if it hasn`t already.If this was at all helpful,please rate,thank you
Jul 21, 2010 | 2000 Ford Escort
Pop up flash wont pop up but still flashs, minolta vetis s-100
Sounds like the spring is broken and needs to be replaced.
Jun 11, 2010 | Minolta Vectis S-100 35mm SLR Camera
Film door on Nikon N70 will not latch! It does not appear to broken. I'm not sure whats wrong?
There is a little spring inside the door latch that moves when you slide cover switch. The spring may be worn out or fallen off. The only way to truely tell is to dismantle the door and switch
Sep 16, 2009 | Nikon N70 35mm SLR Camera
Shaking
Sounds very much like a broken coil spring. On such a new vehicle that seems unlikely but it is possible. Another possibility is a blown seal in one strut. Again, not likely but possible. If you do a lot of off roading or possibly may have hit a curb or pothole hard enough it could have broken an already defective spring or blown a seal in a strut, causing this issue.
Feb 03, 2009 | 1992 Ford F150 SuperCab
Canon eos rebel II
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that relects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
You can also check it by aiming the camera at an object above your head with the camera pointed up since that will hold the little mirror in place by gravity. If it works pointed up the spring is the problem.
You can get the spring from Canon. The part number is CS2-6367-000. Canon's parts dept phone number is 1-732-521-7230.
CameraRepairs
Aug 04, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Auto Focus
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that reflects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
CameraRepairs
Apr 22, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
Jan 12, 2008 | Nikon F60 35mm SLR Camera
Nikon D40x Digital Camera Logo
43 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
