Question about Radio Communications
Midland gxt-850 gets HOT!
Just bought a pair of Midland GXT-850 2-way radios. When I put the some AA batteries in and turned them on, one of them became very hot on the bottom. The 2 posts on the bottom of the radio that charge the battery when in the charger became too hot to touch. I swapped batteries in the radios and turned them back on. Same problem with the same radio.
Any Ideas on what is wrong? Can it be fixed? Or return them?
  • Anonymous Mar 19, 2014
    trying to pop battery off
    Brigadier General:
  • 6,966 Answers
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
  • Louie  Role
    Louie Role Dec 06, 2007
    Hi again,
    Are the AA batteries you are using Rechargeable? If they are and the battery contact terminals checks out OK, guess you're back to seeking replacement.
Midland gxt 756 new batteries but display is too dim to see? No parts broken or loose connections.
Well, there is nothing to repair. Even if you wanted to replace the LED's you would need to open up the radio and figure it out. There are no repair manuals or parts other than batteries available for the consumer grade radios.
Dec 25, 2016 | Midland Radio Communications
My midland gxt quit working,why is that
is there power across the charger contacts ?
get a volt ohm meter & check for starters
usually if you leave the wall wart plugged in all the time they burn out & fail
Dec 25, 2014 | Midland Radio Midland Gxt795vp4 36 Mile...
Midland radio manuals
Download your manual from here:
Aug 12, 2014 | Midland Radio Communications
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
Needing a manual for the GXT 756.
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
The GXT 756 is a variation of the GXT 750, which is covered in this manual here....
Oct 16, 2010 | Midland GXT450VP4 (22 Channels) 2-Way...
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
I have the GXT850VP4 The problem is I lost the owners manual and now the one radio shows a flashing picture of something like a storm cloud.I have no idea what it is or how to remove it Thanx
If you click on the above it takes you through to the manual for your radio.
If you go to p6 NOAA weather (wx) band icon is what you are asking about.If this is showing it indicates the weather band mode.
Hope it helps!
Dec 23, 2009 | Midland GXT850VP4 Two Way Radio
Midland GXT 550 two way radio has a constant RX read out on display as though it is constantly receiving.
my 550 got wet wos leftout in the rain now after three mounths it shows a low battery
Dec 12, 2009 | Midland Two Way Radio
Midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Nov 01, 2008 | Midland Radio Communications
Radio Communications Logo
462 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
