It sounds like you are having some issues with your Neato D80 robot vacuum. Here are a few things you can try to troubleshoot the problem:
Make sure that the bin is properly closed and seated in the vacuum. If the bin is not closed or seated correctly, the vacuum may not function properly.
Check the battery to make sure it is fully charged and properly installed in the vacuum. If the battery is low or not properly installed, the vacuum may not function properly.
Check the charging cord and charging port to make sure they are not damaged and are making a proper connection.
If the problem persists after trying these troubleshooting steps, you may need to take the vacuum to a repair center for further diagnosis and repair.
this is because the battrey of your phone become dead thatswhy it is not charging in any way... so only you have to boost the batrey if ther is anything in the battrey then it will work otherwise you have to change the battrey and to avoid this type of problem don't try to work in low battrey...by this your bttrey life is long...enjoy it and pls vote
You can just park your S50's back tire on a 2x4, look under the battery and you will see a metal case, it has a swing door on it. Remove the Neg and Positive leads, take the bolts out and the battery will slide down and out of the case.
Try working the switches Low/High, Forward/Reverse. Sometimes, the battrey can hang up a bit in the charger, resulting in a low, or no charge. Try a different battery, or recharge your existing battery, making sure that it is firmly seated in the charger.
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
you can turn on your laptop if you dant have an removal battrey n then plug the charge back in and it will work fine however not only that check if the battrey shows any sign of leakeage also once your computer is back on then turn it off again and put the battrey back in if u do not have a removal battrey then keep the laptop unpluged for 5 minutes and try to turn it back on at least 2 times if u have done it then u could try tihis plug the charge wait for ten minutes see if it give u any sign of charging then turn the laptop on .
please try this out and see if it works as im not an it guy but justed wanted to help u
thanks
this is my e mail id [email protected]
can u please let me know if that worked for u or not thanks .
