Question about Mintek DTV-373-D 37 in. LCD HDTV
Mintek lcd w/dvd player
My Mintek lcd tv w/built in dvd player
will not eject the cd
Its past warrenty ,so i took the thing apart to
see if i could spot a mech. problem
i didnt see any problems, and i thought there
would have been a manual release but not
i managed to slip the cd out
put it back together
HOPING
anyway i inserted a dvd and it loaded and played fine
but no eject
Cant i r and r the deck and where can i get one
do you thing its electic or mech problem
thanks for your input
  • 749 Answers
See if the disk tray comes with a rubber belt. if it does then figure it out how to remove and replace it! if it comes with gears then it probably needs maintenance like greasing some part of it causing toomuch friction!.
replace the rubber belt if any! rubber belts often loosen especially with much heat build-up
Posted on Dec 06, 2007
I need a remote control for a mintek 32 inch flat panel tv with built in dvd.the remote control is a RC -600. where can I find one?
It's tough trying to find OEM (manufacturer's) remotes. You could purchase a universal remote and program it to your set. Mintek doesn't have many codes and I believe 259 should do it. Good luck :)
Aug 25, 2011 | Mintek LCD TV Progressive Scan DVD Player
Mintek DVD LCD combo
There's nothing you can do. The DVD unit and the TV are both controlled by IC2 bus lines that work together. You will have to have the unit repaired or invest in another set. My recommendation is " Never buy a TV with a built in DVD player". They do not last. That is from a professional stand point.
Sep 09, 2009 | Mintek DTV-263 26 in. LCD Television
Dvd will not eject when using eject button.
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
May 27, 2009 | Mintek LCD TV Progressive Scan DVD Player
Won't eject disc
I use a produce bag twist tie or a very thin pearing knife. After you push the eject button slide the twist tie in the bottom of the disc slot and the dvd should pop out.
May 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
New mintek flat screen tv won't do anything
Its not the power pack. The problem is with the dvd player which is also where the cable inputs converts through to the tv. if you are lucky enough to find a new internal dvd unit then you are in luck but I have'nt been able to. Your problem is an old isuues at least 2 years old...Sorry no Mintek tech support available.
Mar 31, 2009 | Mintek DTV-373-D 37 in. LCD HDTV
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Buttons don't work
I purchased my Mintek from Costco and had the same problem. They are aware of the problems with Mintek and lack of support. If your set is from Costco or other stores try them for a solution or refund. It worked for me. I got a full refund. Most retailers have a copy of the reciept if not try anyway.
Good Luck
Oct 24, 2007 | Mintek LCD TV Progressive Scan DVD Player
Mintek DTV-373-D 37 in. LCD HDTV Logo
82 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
