Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Wega KV-32FS10 won't power up
For a while now it's been making a louder and louder pop when powering up; then two days ago with a big pop it just went dead. Now: nothing, no light, no led, no sound.
Opened the back, pulled out the one fuse I could find. Appears ok but smoked area on one end might indicate blown. Where can I get a replacement and could this be what's wrong?
  • atlas3650 Dec 07, 2007
    I fixed it!!! Thanks for the help. For anybody else whose Wega KV-32FS10 won't power up, here's what I did: Remove the 20 or so odd screws that have little double arrows pointing at them in the back of the unit. Don't forget the three little screws on the control panel in the back center! The fuse is on the lower right after you pull off the back. It helps to tilt the tv forward slightly to get the back off. Just go to radio shack and get a new fuse, 6.3Amp, 250Volt, 4 for $3. Pop it in, close 'er up and you're back in business (hopefully). THanks to fixya Ijust saved $200-$300.
  • 749 Answers
Not only one component might have been damaged! check for capacitors for bulging on their upper part! also check for open fusible resistors and power transistors for shorts
Posted on Dec 06, 2007
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-32fs10 won't turn on...stand by light blinks continuously
No,ur power ic board converter is dead.
U need a new one.U know some Electronics repairs,open it take off the board where near the A/C cord plug in is use the parts numbers buy it from the Web.replace it that might work, if only the power prob.nothing else.
Aug 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
How to replace the fuse on KV-32FS10?
if you put another fuse in it will blow again horizontal output trans bad
Oct 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
