Question about Canon PIXMA MP160 All-In-One InkJet Printer
Cleaning of cartridges
With which solution should i clean my cartridges, if they are blocked with dry ink
  • 749 Answers
Try 70% of isopropyl alcohol on a tissue paper. wipe it gently. see to it that some or the ink deposit would melt to it! if it does, try to submerge only the head part of the cartridge!
Posted on Dec 06, 2007
Blank pages printing
Sounds like the printhead is pretty severely dried. As standard cleaning cycles haven't helped I would recommend picking up some LC900 cleaning cartridges from eBay etc. These are cartridges filled/partially filled with cartridge flush and break down ink inside the printer.
Most of them contain a mix of ink and flush and you can carry on printing as usual. Given the severity of the dried/blocked printhead you have I would recommend just running cleaning cycles, but leave 10 minutes or so between cleans to avoid overheating the printhead.
Oct 16, 2012 | Brother MFC-5440CN All-In-One InkJet...
Mfc 290, replaced ink cartridges and the black will not print only the colors. printer cleaned and no progress. any help?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 30, 2010 | Brother MFC-290C Multifunction Color...
Have just installed a new black ink cartridge. message tells me to realign the print head How do I do that?
Nov 29, 2010 | Office Equipment & Supplies
Color Ink prints fine but Black ink will not print. Have replaced both black in cartridges and Cleaned several times. Have turned off printer and computer after cleaning. Nothing working.
Nov 22, 2010 | Canon Pixma MP500 All-In-One InkJet...
After cleaning it and replacing numerous black cartridges, My epson stylus r300 printer won't print black ink. What should I do?
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
My printer want print black but have a new cartridge i have a 946 dell printer ...it keep telling me right cartridge missing
You could clean the black ink cartridge. For this you need to remove the blank ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 16, 2010 | Dell 946 All-In-One InkJet Printer
My printer will not print black but is printing all other colours ok
Possible that the B/W cartridge is not contacting or is blocked. remove and fit back. Now remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Nov 02, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Jan 26, 2009 | Brother MFC 420CN All-In-One InkJet...
My Lexmark cartridge, over half full and only 3-4 months old, has malfunctioned. The printer reported that the printhead was blocked. A new cartridge works fine, but I have wasted about $20 of cartridge. I...
Did you run the Maintenance feature that is part of the printer's program?
If not, open the Maintenance page and select Head Cleaning. This cleans the head by pushing through a lot of ink thereby dissolving any dried ink that is blocking the heads. Run a Print check to tell if the heads are properly cleaned (this cleaning may need to be repeated a few times before the heads are cleaned properly).
Good luck.
Apr 14, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
22 people viewed this question
old marine
old marine
