Question about Andis Outliner II Hair Trimmer
Andis Outliner II Trimmers
The trimmers are starting to pull the hair instead of cutting it. And of course I oil them as I should and I even went to the extreme and changed the blades but still the problem exist. I really don't know how old the clipper itself is but its been well maintained. And from what I hear they usually last a while when these are the circumstances. But yet I don't understand why they're pulling the hair. Can you help?
Look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Posted on Jun 15, 2008
  • 61 Answers
Hair between blades
Posted on Jan 26, 2009
  • 62 Answers
If you've been oiling the blades and have also put a new blade on them it may be an internal adjustment that needs to be corrected. Please send your trimmer to the Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177. Please include a short note stating the problem as well as your name and address inside the box.
Thank you for purchasing Andis.
Posted on Jan 08, 2008
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Andis outliner ii
OHOHOHOH
It is always the same to be careful of el. current in different countries.
By my experience I would think that the trimmer will not recover from the exercise.
I hope I am wrong
Kolbrun
Feb 25, 2012 | Andis Outliner II Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
I have some green colored leakage from the handle of my Andis Outliner II trimmers. Is that normal?
if the shaver is working fine i would not worry about it , they use electrical grease and they also use grease on some of the internal working parts . it might be that the shaver got to hot and melted some of the grease . i would just wipe it off .
Jan 15, 2011 | Andis Outliner II Hair Trimmer
How to repair my hair trimmers?
I am a retired hairdresser and it sounds like one of three things or a combination. Your blades may be worn (dull) and need replacement , it may need to be oiled,the blades could be "misaligned" and need to be adjusted. You do that by removing the two screws holding the blades on, remove the blades, while you have them off, clean out any built up clippings in there and then put the blades back on. BEFORE you tighten down the screws make sure the "teeth" from the blades are lined up so the bottom blade teeth can be seen BETWEEN each top blade tooth. NOT directly on top of each other. Now tighten the screws. urn the clipper on and add a drop of clipper oil (no substitutes) onto the running blades. That should do the trick.
Jul 20, 2009 | Andis Outliner® II 04603 Hair Trimmer
Botton don't work on trimmers
Please send your trimmers into the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177. We will be able to repair your trimmer for you. If you would like to speak with a customer service rep first please call 1-800-558-9441.
Thank you,
Jul 24, 2008 | Andis Outliner II Hair Trimmer
Put it back together
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
Andis Outiliner II Trimmers
Please return your unit to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 for repairs. If the unit is less than one year old please also return a copy of your receipt with the unit and all repairs will be done at no charge. If the unit is older than one year there is a $6.50 service fee and $5.00 shipping. There may be additional charges for parts depending on what needs to be done. If you would like to speak to an Andis customer service rep please call 1-800-558-9441.
Dec 21, 2007 | Andis Outliner II Hair Trimmer
Andis Outliner II Hair Trimmer Logo
1,564 people viewed this question
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
