Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The load won't start.
My washer (Whirpool Ultimate Care II) will fill wit hthe proper load of water, but will not engage the cycle. Usually my slamming the lid it will start but it hasn't been doing anything at all. Is there a sensor in the lid, or is this another problem?
  • Anonymous Dec 13, 2007
    The water fills to the proper level; but the washing does not start. I have to open the lid and then close it hard (sometimes slam it really hard) before it starts.
    This started shortly after we bought this machine. I would put the clothes in, add the detergent, close the top and walk away thinking all is well. I would come back hours later only to find the clothes still sitting there not washed. very frustrating... Is the sensor a lemon or what?
    Champion:
  • 249 Answers
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Posted on Dec 06, 2007
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool washer will fill with water, but not complete the cycle
Ok, you will need to replace the timer/control. this device initiates the wash sequence and, if it is damaged in any way, the wash cycle may be interrupted at anytime. simply replacing the timer will fix this issue.
Jun 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
164 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
