HI
WHEN OPENING MY COMPUTER IT SHOWS ERROR CODE 5100 AND I CANNOT PRINT...I DID RESTART MANY TIMES BUT ALWAYS THE SAME MESSAGE AND I CANNOT PRINT
CAN YOU HELP ME TO RESOLVE..
THANKS
Try these steps ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Testimonial: "YOU ARE VERY EXPERT AND RAPID THANKS FOR YOUR HELP I REALLY APPRECIATE IT"
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Hello Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work! Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
it is service error you can fix this by doing this steps 1.hold RESUME then press & hold POWER 2. release RESUME, then press it twice, the light should go amber then green again. 3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once. Hope this helps. Please rate my response. Thanks. Have a good day.
Hi You can Try
Error Code 5100
Solution 1: Clean the timing strip.
Solution 2: The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism. Hope it do for you All The Best: Pineworks
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
I have canon PIXMA ip3000. After power cut at night printer doen not
print. I re installed the drivers but no result. When try to print
message appears printer is offline. POwer button is flashing shorthly
green after orange lights. Error code 5100.
