Question about ASUS P4XP-X Motherboard
How to install driver
Driver...
  • 3 more comments
  • Anonymous Aug 27, 2008
    When I insert a VCD into my CD Rom drive, there is the normal flashing light at the CD Rom but the CD Rom cannot read the VCD.Is it that the CD Rom is spoilt or something is wrong with my drivers or software?
  • evershine25 Aug 27, 2008
    My CD Rom cannot read the vcd which I insert into it.There is a light flashing in the CD Rom drive which it normally does whenever I insert a vcd into it.
  • Anonymous Oct 02, 2008
    BAD DIRECTSOUND DRIVER,PLEASE INSTALL,PROPER DRIBERS OR SELECT ANOTHER DEVICE IN CONFIGURATION
  • Anonymous Oct 06, 2008
    usb
  • indark2 Mar 14, 2009
    I'm Having Color Resolution Problems:
    I have a old windows 98 computer I would like my grandchildren to use for thier games and learning by using CDs. My problem is I cant get the computer to change the color resolution even in the device color manager it is like froze or wont let me change the screen resolutions by which to change to 256 colors. I put in the CD it will start then it has cannot play without 256 colors. I bought a Cd called Ultimate drivers to try and load all nessessary updated drivers but for some strange reason that perticular Cd wont start by just putting it in as the others do. My online connection is cable, and the computer doesn't have the equiptment to get the online internet to work because of age and I dont have the modern equiptment to change the hardware. All I really want to use the old computer for is my grandchildrens use. Can someone give me some insight on how to get my computer offline to change the 2 and 16 colors to 256 colors? It originally had 256 colors when I used it years ago and a friend cleaned everything out of my hard drive so I could start over. The computer seems fine other than these two problems. Thanks so much!
  • 383 Answers
How do I install a computer driver?
Answer: Microsoft Windows users Depending on how the driver has been packaged is what determines how the driver will be installed. Below is additional information about each of the methods developers use to distribute their drivers and how you would install the drivers in Microsoft Windows.
General driver tips
Below are some general insights to help prevent any additional frustration that may be encountered while installing drivers.
Drivers on CD or floppy diskettes:
Almost all computer and hardware manufacturers include a group of drivers for different hardware devices and often for each of the supported versions of Windows. For example, the driver CD you receive with your printer likely contains the drivers for dozens of different printers. Not just the printer you purchased, which means when installing the drivers make sure you're installing the drivers for your printer, not another printer model and that you're installing it for the version of Windows you're running on your computer.
Below is an example of how a file structure may look on your disk.
CD Example:
-PrinterA100
--Win9x
--Win2k
--WinXP
-PrinterA200
--Win9x
--Win2k
--WinXP
-PrinterB100
--Win9x
--Win2k
--WinXP
If for example you had a PrinterA200 and were using Windows XP you would find your drivers in the PrinterA200\WinXP directory.
Downloading drivers:
Almost all drivers you download are going to be a single file if the file is not an executable file it is almost definitely a compressed file that contains all the driver files. In order to install the driver you will first need to uncompress the file. Additional information about how to uncompress a compressed file can be found on document CH000506.
When extracting / uncompressing the drivers make sure to remember where you place the folder containing the drivers as you will need to point Windows to this folder when installing the drivers. We usually recommend users install the driver files in a folder on their desktop as it's an easy place to remember and locate.
Finally, the single file and/or the files extracted from the compressed file can be deleted after you have finished installing the drivers.
Executable
Many computer and hardware manufacturers today are pre-packaging their drivers into executable files or have the drivers installed through the setup file, which means simply double-clicking the setup file or the file you download should install the drivers to the computer for you.
Note: Many developers may package their drivers in a compressed file, which means before looking for the setup file you may need to uncompress the downloaded file. Information about doing this was explained above. If after uncompressing the file it still does not contain an executable file, some type of setup file, or does not install your hardware device continue with the below recommendations.
Finally, if you were successful in installing your drivers make sure to reboot the computer after the drivers have been installed.
Using the have disk option
Often computer manufacturers and hardware manufacturers will also simply place the drivers on the CD, diskette, or download for Windows to find and use during its hardware detection. Below are steps on how to install drivers for a new device and upgrade a devices driver for this type of setup.
Installing a new device
Upgrading drivers for pre-existing device
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
  2. Once Device Manager looks ok reboot the computer.
  3. As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive
Install through the .inf file
Finally, if the above recommendations do not work the installation instructions for drivers and hardware devices are always contained in a .inf file that is located within the drivers.
Locate the .inf for your version of Windows right-click that file and choose the option for install. Note this is a very raw form of installing a drivers and it is important that you make sure you're installing the correct .inf file and not a .inf file for another device or for a different version of Windows. Additional information and tips about locating the drivers was explained earlier in the general driver tips section.
Once you have right-clicked and installed the driver reboot the computer
One of the above three recommendations should have installed / updated the drivers successfully onto the computer. If you're still having difficulties getting the device to install it's possible you're not encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
Dont for get to Vote
Merry Christmas....Good Luck!
Posted on Dec 06, 2007
I don't know how install driver to positivo sim 1025, like a special manner to do it . I tried almost every manner , but work partially only , and if restart, don't have audio driver active
install chipset driver 1st then install then install graphics driver then install audio driver then other driver or install the chipset driver 1st then install other driver using device manager
Jan 11, 2010 | Computers & Internet
Im trying to install a sound driver but there's an error
The driver may be imcompatible. Go to the device driver and first uninstalled the driver. Then, discover new hardware and let the driver install again. If that does not work, try uninstalling to previous driver. Lastly, try to "roll back driver" to previous version. I hope this helps.
Jun 24, 2009 | Compaq Presario 700 470024-192 Notebook
Microsoft Bus driver to windows xp
You need to install the chipset drivers before it will take the audio driver.
Go here to Acer support, download and install the chipset driver, then you can install the audio driver >>>>>>>
http://support.acer-euro.com/drivers/notebook/as_5630.html
Good luck
Jun 15, 2009 | Hypertec Phoenix 370/S (HYPH01)...
Driver teac webcam driver zl200530063216.4 i want it plz tell me address
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 14, 2009 | Veo Stingray
Sound driver installation problem
HAVE YOU UN-INSTALLED THE PREVIOUS SOUND DRIVER BEFORE YOU TRYING TO INSTALL THIS ONE? IF NOT, AND YOU ALREADY HAVE A SOUND DRIVER INSTALLED, YOU WILL HAVE TO UN-INSTALL IT OR DISABLE IT UNTIL YOU GET THE NEW ONE INSTALLED. THEN SET THE NEW DRIVER AS YOUR DEFAULT DRIVER ONCE INSTALLATION IS COMPLETE.
May 31, 2009 | Compaq Computers & Internet
Driver Problem
Jan 28, 2009 | HP Pavilion dv2000t Notebook
Driver Compaq Presario C700 notebook
Only for windows xp steps........
u should always turn off automatic updates.......and install drivers it will be work fine..
I will give u all drivers link....go to hp.com and search it..
for modem -sp33442, for audio-sp35270, for sm bus controller-sp36492, for quick lounch sp38171, for UAA sp32395, for webcam sp37849, download all drivers and install it.
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
wifi driver link:
http://www.atheros.cz/download.php?atheros=AR5007EG&system=1
good luck
Jan 05, 2009 | HP Compaq Presario C700T
Can't install pci modem driver on my laptop
Usually this occurs when the drivers are not installed in the correct order. The install order is:
Notebook System Software
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
Wireless Driver
Touchpad Driver
Nov 28, 2008 | Dell Inspiron 8600 Notebook
Need installation software
Kevin download drivers and software to suit HERE - please rate
In case I stuffed the other link link
Dec 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
ASUS P4XP-X Motherboard Logo
2,172 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
