Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Amana refridge fridge will not work. freezer is on the bottom and he doesn't work either. lights come on and fan motor is running. the compressor makes a humming noise every 5 minutes or so. I'm pretty handy so it's not a problem for me to fix but I just don't know if it's the compressor or something else. thanks!
  • grammee May 02, 2008
    The freezer is working fine but the frig portion is blowing hot air.
  • 828 Answers
The humming noise is the compressor cycling on the overload protector. By the posted date I would think that you already replaced the refrigerator.
Posted on Apr 30, 2008
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Sep 20, 2009 | Refrigerators
Running warm. how do I recharge freon?
There are no service valves on refrigerators for charging.(They must be added).
It may not be a refrigerant problem.
Is the freezer fan motor running?
Is there a frost/ice buildup on the back wall of the freezer?
Is the compressor fan motor running?
Is the compressor Running?
These are the first steps to verify before suspecting a refrigerant leak.
Sep 05, 2009 | GE Refrigerators
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
the condensor fan motor is bad!! Pretty soon the compressor will be too! Take the back cover off and put a fan blowing on the compressor this will help until the fan is replaced!!! Please!!! A solved rating for this one!! Its dead on
Oct 04, 2007 | GE Americana A3316ABS Top Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
