Question about Sony KDE-50XS955 50 in. Plasma HDTV
Sleep timer not a fix
The sleep timer did not help in making the tv stay on. it still shuts off in 1-2!
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
Posted on Dec 21, 2007
Daenyx dn191 does not stay on. it shuts off after 30 minutes of being on
Check the tv menu setup,check for the sleeping timer it is not on like Sleeper modes or timers,make sure it not on like 30,60,120 mins.Should soved this promblems,if not tries find the new version of the tv firmware on the manifacture website make sure it correct tv make model tv software firmware and down load it to a flash drive uploaded to ur tv,this is a once time shot only.Don't make a mistake or u have to replace the whole main mother logic board.
Aug 09, 2013 | Daenyx Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
How do i fix my sony tv sleep timer it a trinitron
There is a SLEEP button in the remote of Sony trinitrone TV. Press repeatedly until the Tv displays the time in minutes (15,30,45,60 or 90) that you want the TV to remain ON before shutting off automatically. Cancel by pressing until the SLEEP OFF appears.
Hope this will help you.
Thanks for using Fixya.
Oct 24, 2010 | Televison & Video
How do I use the sleep timer button?
Well you may please follow the steps below -
Step 1: Press and hold the "SLEEP" key, then release. The indicator light will stay lit.
Step 2: Enter time in minutes using the numerical keypad (from 1 minute to 99 minutes). For 1 to 9 minutes press 0 before the actual number. The indicator light will go off. Leave the remote aimed at the TV set.
The Sleep timer program can be cancelled (reset to zero) by pressing and holding the "SLEEP" button until the INDICATOR LIGHT blinks or by pressing the ON/OFF button.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | RCA RCU410W Remote Control
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Oct 06, 2010 | LG 32LG30 32 in. LCD HDTV
Disney pixar cars tv/dvd combo turn on but shuts off in minutes
Ours did the exact same thing.. I Decided the remote thing was worth a try. I turned the TV to DVD (without a DVD in the player) pressed the set up button (on remote) and Restored the Default option. (Highlighted Default; highlighted Restore then pressed OK) Then exited the set up. I did this twice just to make sure, LoL well.. it's been on over 4hrs now with no problem.. seems like this fixed it.. hope it helps!!
Mar 10, 2009 | Disney Electronics Single Disc Boombox,...
Powers off
check to see if our tv timers are on weekly or sleep timers may be causng the problem and shutting down and a given time
Oct 19, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sony KDE-50XS955 50 in. Plasma HDTV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
