Question about Husqvarna Viking 1
Husqvarna Viking 6440 buttonholer, reverse frozen
My Viking 6440 will straight stitch, but the buttonholer, reverse, stitch adjustment are frozen. The cam will turn and is not cracked at the assembly, but it is stiff & hard to rotate. The local Viking dealer wants $379 to service this. Does anyone know where I can buy a service manual for this machine? I've had it since it was new in 1976, over half my life, and I don't want to part with it, but can't afford that expensive of a service. My husband can fix anything if he has a manual or someone to answer questions (like what type of lubricant to use).
Thank you!
  • 2 more comments
  • Anonymous Dec 11, 2007
    I had my viking 6440 tuned up a year ago, I hadn't used it much since. I went to use it the other day and it got stuck in reverse. It sews fine in reverse!! Any way the dealer said I probably need a new cam stack (?). I am going to use some electronic lubricant to see if it is just gummed up in there, Otherwise it'll be between $200-$300.
    My 6440 is stuck in reverse, it sews fine in reverse.
    A repairman pulled out the cam and briefly glanced in and said the cam stack (?) is broken...... $200-$300, I am going to use some electronic lubricant, to see if it is just gummed up.
  • dk_0000 Sep 27, 2008
    My Husquarva # 1 is stuck in reverse. I've heard it is expensive to get fixed ($300.00 ouch!) Any ideas on what to check before I take it in for service?
  • Sally79 May 04, 2009
    I have the Viking 6440 and have a similar problem. It straight stitches forward fine (so far) and the reverse buttom is working for straight stitch . The problem is it stitches in reverse when I program for zig-zag or one of the decorative stitches using a cam. The cams insert smoothly and rotate, but do not produce a decorative stitch. It sews in reverse. Any one have any solutions short of a $379 repair. I love the machine and don't want to part with it ever.
A seller on e-bay who redoes Viking machines says the the grease they put in them (the older vikings) becomes too stiff and the knobs stop turning. He cleans them out and then he adds some kind of teflon lubricant. Probably can find him on e-bay still. He is informative.
Kathy
Posted on May 21, 2008
Why cannot I move the select switch on my viking. It will not budge?
It sounds frozen. Unscrew the spool holder, and take off the back panel. Oil all metal parts. Do not get oil on the motor, or light. Work it back and forth with the hand wheel until it becomes free.
Mar 04, 2015 | Sewing Machines
Does the husqvarna viking quilt designer 11 sew straight stitches without using a card?
It is possible but it will only sew a straight stitch (more than likely a 2.5MM stitch length which is a common/standard length for straight stitching.
Jun 28, 2014 | Husqvarna Viking 1
6440 sewing
This is not programed into the machine. You could do it freehand.
Dec 24, 2013 | Husqvarna Viking 1
Viking 6430 buttonhole help
Please post the link to the manual so others who need it can find it easily. Thanks.
Aug 01, 2012 | Husqvarna Sewing Machines
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
Our sewing machine is only running reverse (backwards) Can you please provide me we an service manual, type husqvarna 2000, modell 6440
You can find the service manual here.
http://www.sewingnz.com/categories/Husqvarna-Viking/
and a video on this page.
http://www.absolutesewing.co.nz/SewingHusqvarna.html
Your husqvarna 2000, model 6440 machines mechanical parts are in the need for a good clean and oiling. There is an explanation to this on the blog below.
http://sewingnz.blogspot.com/2011/04/repairing-reverse-on-husqvarna-2000.html
Apr 01, 2011 | Husqvarna Sewing Machines
Viking Husqvarna Model 6020 stitch selector will not turn.
Apr 23, 2010 | Husqvarna Viking 1
Button holes husqvarna 6440
Use the "C" foot.
Set the "Stitch Width" dial to 0, then pull it out. You will now be able to rotate the knob and, if it is working properly, you will get the 4 parts of the buttonhole. Rotate to 1 and sew the left column, 2 for a bar tack, 3 for the right column coming down the other side and 4 should close it off.
The knob may be rotated back around to start another buttonhole by rotating forward. When it is pulled out, it will not stop turning at 4.
Always set the know to 0 to pull it out or push in.
May 31, 2009 | Husqvarna Viking 1
Sewing Machines Logo
1,497 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
